Hey guys
I have a HKS SSQV, it is the newest style refer below picture. The valve is currently on my R33 GTS-T.
However I am going through a series of upgrades atm and want to return to a legal setup due to the current upgrade requiring a mod plate so i need it to be 100% legal. So plumbback is the best way to go and turbosmart offer the product i want. I do need a plumb back bov which can flow some massive air...
Im after a turbo smart bov of the following model number;
FG-BOV-003PB38 – (38mm outlet) RRP $299
This is a picture of the valve im after. I would prefer the 38mm version.
What im after is either a swap for the turbosmart valve listed above or $350 for the ssqv bov postage included anywhere in Australia. Yes you do get the all the bits need to fit it to a R33 cross over pipe.
I do have recipts for $670 for the valve and fitting kit.
This is NOT a chinese copy and has only been on my car for about 7000km's.
Please post here or PM.
Cheers Col
https://www.sau.com.au/forums/topic/127951-hks-ssqv-bov-wr33-fitting-kit/
hey buddy
i'd take it off ur hands... however i've got a sr20.. and not sure how it'd go fitting it to my car
You would need to buy the fitting kit for an Sr20 which is like 100 bucks...
I'd like to talk to you about buying the BOV Col. I have questions and would like to test it first also.
Dave
Yeah no worries mate... Can do for you...
  • 2 months later...
Col i have a mate that bought that model bov for his s13 but never ended up fitting it - i'm not sure but he might still have it, i'll find out for you.
Bump... Last one in this condition sold for $420 on this very forum only 2 weeks ago...
BARGIN
EDIT: Im going to keep this now, as i found out there is a plumb back adapter for it, which will make it the best plumb back bov on the market. Being that it is a pull type valve and cannot leak under high boost...
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
