R32 Gts-t Rb20det 5 Speed, 1992 model
Engine Mods: Rebuilt RB20det only done 10,000k's on it
Tomei Poncams
Ported polished head
1.2mm nismo metal headgasket
brand new rebuilt head
gates racing timing belt
greddy remote oil filter relocator with oil cooler
custom made plenum front facing polished alloy
6 boost custom made exhaust manifold
Greddy TD06-20g with 8cm rear housing
Tial 38mm Wastegate
3inch dump with high flowed cat and 3.5 apexi catback exhaust
HKS type s front mount intercooler
blitz pod filter
Apexi Power fc with hand controller
GTR injectors wired in with resistors
Power fc boost kit
Sard fuel Regulator
Bosch 040 fuel pump
Brand new Clutch master cylinder
Exedy 5 puk heavy duty race ceramic clutch
Q45 Air Flow Meter
Brand New Alloy Radiator 40mm thick
Suspension:
GAB Coil overs with adjustable heaight and damper
Rear camber arms
Rear subframe alloy bushes
Strut braces
Interior:
very clean interior no ciggy burns anywhere no scuffs or scratches anywhere
3 blitz racing electronic gauges oil temp/oil pressure/ boost
blitz turbo timer
Brand New Eclipse headunit with focal 6 inch component speakers with tweeters
Now has R33 GTR drivers seat (perfet condition) and R32 Gtr Passenger
Exterior:
Genuine GTR Front Bar
With sideskirts and rear pods
Now has Gold Drift teks 9.5 inch wide rear and 9 inch front
Rego till 7th 08, gets serviced every 4000k's, always runs mobil 1 oil, Colour is wine red, has black tint all round, This car is genuinly quick for an rb20det, made 315rwhp on only 15 psi have dyno sheets, never driven is always parked in the garaged thats why i am selling it...
Located in queensland
Price: $16000
email [email protected] for pics
Phone: 0423408914
Edited by Waldo
https://www.sau.com.au/forums/topic/128411-r32-gts-t-315-rwhp-on-15psi-16000/
  • Replies 41
Posted Images
yeah it has to be. it's daniel the dude from saturday with the silver r33. i cant belive your selling your car. what are you looking to trade for? if your interested in a swop my cars probalby a bit more city street practical in terms of comfort and low down torque. it's got a fairly expensive stereo, power fc, fuel pump, gates belt, 3" titanium exhuast, gtr front bar, monkey wearhouse fmic, k&n pod filter, adjustable exhuast cam gear 18" dished rims. You got me hooked on saturday and i want to do what you were doing so your setup would be ideal. let me know
  • 1 month later...
  • 11 months later...
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
    • Welcome mate. Any pics? Even with a DE I'd be well happy if I had that as a 1st car.
