Hi, I posted this in the FAST software thread before I found this one. I am new here but I am in the process of buying a R32 GTR VSpec II (in compliance now) so I can retire my 92 Mazda Familia GTAe. Just want to get it all checked by you guys.
Chassis No — BNR32-311484
Model — KBNR32RBFS8ZAA
I am pretty sure it is all legit as it is a reputable dealer.
Can someone also tell me how to decypher the model number? i.e. what all the letters and numbers mean?
Thanks and great site by the way.
Dude, I couldn't be bothered waiting anymore so I just called local nissan dealer, asked to be put through to spare parts, then asked if they could FAST my car. They did it over the phone and everything checked out, whole process took about 5 mins if that.
haha all good im happy to wait, im sure mine is a genuine 32 GTR vspec II as well. Just wanted that comfort in having info to back it up :cheers:
Yeah fair enough. I just needed to know asap because I was finalising purchase, otherwise I would have waited. Sorry if I sounded like I was impatient didn't mean to.
Anyways I agree with you, would be great to see with my own eyes. Hey Chook, any chance of still getting mine done too seeing as though Hanyou's and the 34 got done??
ill post model code stuff in following post for you to go through.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
