could you do mine for me aswell please kind sir
ecr33109237
ecr33109237
could you possibly check my VIN?
vin-ER33-004493
model-BGKARGNR33EDAB
cheeers.
Hmm my version of FAST (v3.5) can't find that VIN or model number. Are you sure they are correct? Could someone else also try and FAST that VIN number too?
hmm thats strange.. i didnt think there were any 1993 4 door r33's.. actually i just realised that cant possibly be my car because the model number is un accurate. anyway for anyone who wants to download Nissan FAST for themselves, i found a good torrent.
http://isohunt.com/torrent_details/9042828...ast?tab=summary
you will need uTorrent or bitorrent & it is about 1.6 gig, seems like its going to take ages to download but it took me like 3 hours roughly.. pretty good. then follow the instructions exactly. and it works great no viruses or anything..
Edited by azzafreddy
it says ER33-004493, but maybe its ECR33-004493? i had a browse through this blog and couldnt find any other R33's with ER before it only R34's..
hey Aaron
this could just be a F up in FAST, I used your model and got the following details, I does tell me the ER33 part IS valid
could you guys check this for me im thinkin of buyin.
BCNR33 004572
GGJPRWFR332DA
thanks
mmmmmm, another V-spec ..... :thumbsup::D
Cheerz
cheers mate, i did the same thing to doesnt make a whole lot of sense tho its all wrong, cars a DET not a DE & i know its a 94' but oh well :thumbsup:
yea FAST gets a bit funny @ times, I've had VIN's that come up invalid, then reboot 'd my PC, and suddenly their valid ????wtf
others that will not work on mr Ver 3.5 but they work on other versions of FAST ?????
weird $h1t...
don't 4get your paint code, interior color and date of manafacture are on the compliance plate anyway,
FAST is mostly 4 looking up part numbers, rather than verifying a car identity though
Cheerz
weird $h1t...
Cheerz
Yeah it sometimes doesn't work, I put in azzafreddy's model number and It returned invalid, although BundyBear was able to get it. Sometimes other people need to try it and it works. Anyway, atleast you got what you wanted now :cool:
hey guys, can i get this checked please.
hcr32-290845.
thanks.
hcr32-290845
yeah for sure, i couldnt do it myself on Nissan FAST v3.5 using the vin number, so i tried typing the vin number and the model number in (model followed by ----, otherwise it wouldnt work) and it came up with the info. its a funny system thats for sure :cool:
What is the number stamped into the firewall? That number most likely is the correct one.
    • I don't know for sure, but I'd expect them all to be interchangeable given the diff end and hub end don't move/change between any C34 series. Often Nissan will change part numbers and the aftermarket follows those year ranges; but the original part number change doesn't mean other parts won't fit. The change could be a change in material, internal parts or even just supplier. For example, all the RB gearbox to engine bolts are no longer available and there is a new part number instead. The only change is they went from cadmium plated bolts to zinc plated due to the issues manufacturing with Cadmium. They look different but work the same.
    • One year is a bit concerning. Did you try contacting GSP? It says 5 year warranty on the box if I remember correctly. I'm also running their driveshafts on my S2 Stagea.   You could check the part numbers on Amayama for your year. Here's the link for my 1998 which gives the 39100-23U60 part number. Well, that and 39100-23U70. https://www.amayama.com/en/genuine-catalogs/epc/nissan-japan/stagea/wgnc34/6649-rb25det/trans/391 What does it say for yours?
    • I ordered a GSP Front R/H Axle from here - https://justjap.com/products/gsp-premium-front-driveshaft-r-h-nissan-r32-r33-r34-skyline-gtr-stagea-4wd#description It lasted around a year before one of the boots blew out. I'm lowered, but I have GKTech roll center adjusters. One year seems a little premature. I think I'm going to spend the extra money on an OEM cv axle this time. This website - https://tfaspeed.com/collections/nissan-stagea-wgnc34-x-four-parts/products/nissan-stagea-awc34-260rs-rb26-right-front-axle-drive-assembly Makes it sound like the readily available OEM CV axle will only fit 11.1999 Stagea and up (mine is a 2.1997 S1). The JustJap listing didn't mention any years or anything for the GSP axle. Amayama shows '11.1999' and up as well for that part number. As well as 'plastic boot type'. See attached picture. So I guess my question is, does that axle (39100-23U60) really only fit S2 Stagea? It's the front driver side. If it does, I'd love to buy that instead of rolling the dice on another GSP. I've found that OEM one cheaper here: https://www.partsfornissans.com/oem-parts/nismo-jdm-r32-r33-r34-skyline-gtr-r32-gts4-right-front-axle-3910023u60 and here https://www.nissanparts.cc/oem-parts/nismo-shaft-ft-drive-3910023u60 Just a little confused because the JapSpeed listing for the GSP front driver axle doesn't mention any specific years or anything and it fit my S1 Stagea fine. So will 39100-23U60 fit my S1 Stagea even though technically it says '11.1999' and up? What would have changed? Thanks.
    • Thanks for the info. The only "Issue" I've had with the shifter is I always found the throw between 4th and 6th gear too close. I'm always worried to shift into 4th accidently and sending my motor to the moon. Adam LZ recently came out with a video and stated Serialnine revised their shifters to correct this and will change all the revised parts for 150$. Strangely enough, I contacted Serialnine right after and they denied it and said it's bullshit. I found that strange as he's a distributer. I'll keep this forum post updated on that saga.
    • Yep that is correct. It allows you to adjust the short throw range from what I can tell
