Any chance of a fast check on the following vin number to confirm whether this vehicle is a genuine Autech 260... VIN# 6U900WGNC34137440 thanks.gif
So... WGNC34 137440 doesn't spring up the "this vehicle is an autech blah blah" warning that the rest do.
I was checking this for a mate who is looking at buying it. Funny enough... MY Autech 260RS did not come up as genuine on FAST. Yet everything on the car (except for the FAST) tells me it is one!
Fair enough, i'm not sure how reliable Nissan would be at keeping track of modified cars? I would guess the database would only know of the cars they sold directly to Autech, or the database could be updated over time with whatever information Autech give to Nissan? Meh.. buy a car to enjoy it, not for resale value eh? =-]
Exactly! I was pissed off when FAST said it ain't an Autech. But now I am like, meh. I love the car!!
Can we fast 6U9000BNR32007072 please. It may be a nismo version.
Checking for a mate!
This is my GTR, I bought it last friday.
http://www.skylinesaustralia.com/forums/topic/180772-for-sale-1990-skyline-r32-gtr/
Doing some research on the car as lead me to belive it could be a R32 GTR Nismo Version. So was wondering if that the VIN might tell me if it is or not.
Hi, Need to solve my mystery....
Engine Number = Rb260519684
Vin Number = 6U900BCNR33004065
Model Number = 66JPRWFR332DA
Cheers,
Kyle.
Sorry to be a pain,
Can I get any more addition information or is this all I can get?
It is just that I have found out that my wiring loom for my GTR is different to that of a standard GTR and a Vspec.
    • From my youth: GTi-R clutch change is a massive pain. The gearboxes are fragile? But the car is super cool and I want one 😢
    • Remember this is 1988 tech.
    • Driveline vibration is resolved. I ended up loosening all my engine mount and trans mount bolts, giving it a good shake then retightening everything and it's gone... Let's just say I was surprised that fixed it.  I've been happily driving it around again but unfortunately put zero time into my direct port/constant pressure WMI setup. I'm on vacation next week, so I'll try and finalize it then.  On a different note, I spent all week fuel/ignition mapping 2x 216L V16 engines. Turbo's were burning glycol and we swapped them out for larger units. We also had planned emissions testing on site, so I figured I'd be there the same week to use their instrumentation and massage any emissions issues out if needed. This was a first for me. Fuel management is similar in certain ways to automotive (i.e air density as load variable) but very different in others. It's all PLC based and AFR's are controlled by air and not fuel. They use a control valve between the turbo and air manifold to control pressure which in turn controls AFR's. Due to this, target AFR tables supplied by the OEM are in pressures and not mass which really through me off. They use air pressure vs fuel pressure tables. I also relied on an O2 concentration sensor the emissions team had in the exhaust. Ignition timing was also all over the place and we were losing a fair bit of power. They're now happily sitting at 16-40BTDC depending on load. We were making about 1600kw at 900rpm at 90% load. Engines were running a lot smoother as well.
    • heh, aint no R32 ever meeting modern targa cage rules unless the driver is veeeery short OP, good luck with the sale, since its already in the land of freedom I'm sure you will find a good buyer.
    • meh, it was a good video, clear about the issue and how he dealt with it. A bit heavy on the RTV and very brave to put an RB in anything without rebuilding it first, but otherwise I thought it was good Dose, I'm not sure that having the pickup forward is a big issue; yes of course the oil could shift under brakes but the sump should never be empty enough for that to be a problem (unless you also have a higher volume oil pump, and that oil can't return from the head to the sump quickly enough)
