Hey mate, can i get mine done.
ECR33020056
Cheers.
Doesn't work in my fast which is 2009 version. My parts car vin didn't work either which is fairly similar. Strange.
If you have the model code I can chuck that in and it might show some of the info.
Edit: Rob it works in yours? Can you try ecr33-026274?
Hey Rob
I know Michael ran this vin, but your Fast looks as though it has a little more info.
Please would you be able to run this vin for me? bnr32302657
Cheers Robbie.
ps. Sorry for being a bit of a Knobjockey.
Sincerely.
Benjamin Dover.
:nyaanyaa:
Hi Rob
my chassis no is ER34-023722
Could you run a ckeck on my wheels mate..thanks mate..
:thumbsup:
hahaha good one rob. Keep it up, good to see you've got a sense or humour
Not trying to be a dick.
cheers rob
No Worries.
hey mate can you run this please, cheers mate.
ECR33114114
M refers to the car being M spec and I think (and correct me if I'm wrong), the 1 may be the options package fitted from factory??
AT:F4 definately was Auto from factory (mine was too) and perhaps the F4 is the type off gearbox (4speed) but not sure what the "F" means. If changed from auto then your speedo cluster should be a manual one which casts doubt on the true Kms of the car.
(like mine). :/
TM1 means it's got the A-LSD, your cluster has a slip light that works?
Actually I'm wrong TML is A-LSD, TM1 is acccording to hyperrev and google translate "Aero selector sucrose solution" Some kind of special Aero package?
Maybe someone else can translate it better? エアロセレクショソ
    • Hey guys! Y'all are the masters so figured I'd check in on a few items here. - My engine sounds ever-so-slightly more raspy than the other NA RB25s I've listened to. It's barely noticeable but definitely a slightly different sound. - When I back off the throttle at high RPM, I will sometimes get a pop out of the exhaust, assuming this can be diagnosed as misfire. Some history on the car: - Had an exhaust leak in auction sheet but was claimed to be fixed by seller (bought from USA importer).  - Car's coil packs and sparks were replaced when it was sold to me, but unsure on what the gap is and whether the coil packs are correct.  - A prior mechanic had misdiagnosed a pilot or throwout bearing sound as LSPI/detonation. Had played with timing a bit, pops/raspy sound of engine just got worse. Got timing reset. - Had failed emissions a few times. First time went in as is, failed. Second time, replaced cat, still failed, running rich as hell. Third time replaced o2 sensor, passed. Car still smells gassy though. - Timing belt and valve cover gasket also replaced.  - Gas mileage is... low. about 350-400K per tank.  Any idea if I'm having any serious issues here or does this all sound like normal old NA RB stuff and I'm fine to drive it with the pops/slightly raspy engine? If it'll help, I can get drop a video of the sound of the engine.
    • So....to find any R chassis part number, get your VIN (will be something like ER33-xxxxxx for you) and go to: https://www.amayama.com/en/genuine-catalogs/nissan and enter it. From there you have access to a web version of Nissan's part system, FAST. It is a bit tricky to get used to, so maybe have a shot and post up what you think.  You can also search by general model but note in some cases your car might have different options so VIN is safest.  On diagram 211 I got 14075-75T16 for Connector, Water Hose If I search for part 14053‑21U10 that you posted, that is also a water hose but not the one bolted to the plenum and 14075‑04U00 is the fitting where the water hose goes into the block.
    • Yeah now we are talking I much prefer coolers in the front middle because it lessens the chance of a small bump to a corner stopping the whole event. I was thinking the AT cooler can move out of the radiator, delete the AT/engine coolant interwarmer and mount a separate cooler with a thermoswitch somewhere further back as is common in racing, that would be one thing. Beyond that, the engine oil cooler is an obvious one to move to the wheel arch, potentially one on each side, but unused space is an issue. I did have a earlier pic with the bumper off but it doesn't show how busy the corners are: DS is full of the auto driving sensors and PS is totally fully of windscreen washer fluid reservoir But ultimately I was hoping to keep the AC, and the water/air heat exchanger is fundamental so it is not just the radiator that needs to be in front BTW here's airflow to the rad as it ran at the track (one horn is gone now and I'll remove the lights next time):
    • your right the maps for Australia came out in 2017 but are 2010 maps. i got the updated maps SD card put it in and it was the same. Same maps in my Brothers Nissan Patrol. 2020 i think his car is
