Ok who has a copy of FAST that covers late models?
PM35-600544
Need the options list.
I'm assuming you don't need them badly translated? Let me know if you do though.
Edit: New pic which includes the rest of the details instead of just options.
hi thanks so much for getting on this request !!
can you tell me what u see from the info like what my car came with factory etc for equipment standard
I see it has different bumpers, skirts, has the v spec areo kit im sure, has the bigger brakes ....
I would of asked in my own country Canada .... but the members of GTRC are not quite as informed as u guys are in the skyline game
.... so ask the experts
i have Brembo Brakes are those listed by chance
thanks so much
Edited by Collector-1313
Hey mate unfortunately with these earlier models it's a little more difficult to grab the info for the options. With later models(33 onward, 93 or so onwards it seems) it gives you a box with all the oprions for that particular car like up the page but for 32 and earlier it gives you a bunch of charts etc that you need to look through so it's a bit harder to work out what's what.
oh i see .......
okay thats a shame for me anyways cuz i kind of started a up roar of mixed emotions on this car .....
people are hot to say what it is and what it isnt but no one can say for sure hahahah
if you do happen to rip some info out of some dusty area of Nissans history please let me know
and sorry for not introducing myself, i am a new GTR owner from Canada !!!
I will be using this form rather than GTRC for the vital info that matters !!
thanks from Canada Everyone !
if theres anymore info anyone please share
hey thanks ,do you have # for skyline badge between tailights ..should be the same as your car ..nissan told me i need to buy complete panel to get badge.. :wacko:
Looks like you do have to buy the whole trim panel :(. The S2 ones don't come unpainted either you have to get it in a factory colour. 84810-26U07 is the KR4 part # but not sure if that's the silver your car is, should be though. Just shy of $350 through Amayama :S
    • I know why it happened and I’m embarrassed to say but I was testing the polarity of one of the led bulb to see which side was positive with a 12v battery and that’s when it decided to fry hoping I didn’t damage anything else
    • I came here to note that is a zener diode too base on the info there. Based on that, I'd also be suspicious that replacing it, and it's likely to do the same. A lot of use cases will see it used as either voltage protection, or to create a cheap but relatively stable fixed voltage supply. That would mean it has seen more voltage than it should, and has gone into voltage melt down. If there is something else in the circuit dumping out higher than it should voltages, that needs to be found too. It's quite likely they're trying to use the Zener to limit the voltage that is hitting through to the transistor beside it, so what ever goes to the zener is likely a signal, and they're using the transistor in that circuit to amplify it. Especially as it seems they've also got a capacitor across the zener. Looks like there is meant to be something "noisy" to that zener, and what ever it was, had a melt down. Looking at that picture, it also looks like there's some solder joints that really need redoing, and it might be worth having the whole board properly inspected.  Unfortunately, without being able to stick a multimeter on it, and start tracing it all out, I'm pretty much at a loss now to help. I don't even believe I have a climate control board from an R33 around here to pull apart and see if any of the circuit appears similar to give some ideas.
    • Nah - but you won't find anything on dismantling the seats in any such thing anyway.
    • Could be. Could also be that they sit around broken more. To be fair, you almost never see one driving around. I see more R chassis GTRs than the Renault ones.
    • Yeah. Nah. This is why I said My bold for my double emphasis. We're not talking about cars tuned to the edge of det here. We're talking about normal cars. Flame propagation speed and the amount of energy required to ignite the fuel are not significant factors when running at 1500-4000 rpm, and medium to light loads, like nearly every car on the road (except twin cab utes which are driven at 6k and 100% load all the time). There is no shortage of ignition energy available in any petrol engine. If there was, we'd all be in deep shit. The calorific value, on a volume basis, is significantly different, between 98 and 91, and that turns up immediately in consumption numbers. You can see the signal easily if you control for the other variables well enough, and/or collect enough stats. As to not seeing any benefit - we had a couple of EF and EL Falcons in the company fleet back in the late 90s and early 2000s. The EEC IV ECU in those things was particularly good at adding in timing as soon as knock headroom improved, which typically came from putting in some 95 or 98. The responsiveness and power improved noticeably, and the fuel consumption dropped considerably, just from going to 95. Less delta from there to 98 - almost not noticeable, compared to the big differences seen between 91 and 95. Way back in the day, when supermarkets first started selling fuel from their own stations, I did thousands of km in FNQ in a small Toyota. I can't remember if it was a Starlet or an early Yaris. Anyway - the supermarket servos were bringing in cheap fuel from Indonesia, and the other servos were still using locally refined gear. The fuel consumption was typically at least 5%, often as much as 8% worse on the Indo shit, presumably because they had a lot more oxygenated component in the brew, and were probably barely meeting the octane spec. Around the same time or maybe a bit later (like 25 years ago), I could tell the difference between Shell 98 and BP 98, and typically preferred to only use Shell then because the Skyline ran so much better on it. Years later I found the realtionship between them had swapped, as a consequence of yet more refinery closures. So I've only used BP 98 since. Although, I must say that I could not fault the odd tank of United 98 that I've run. It's probably the same stuff. It is also very important to remember that these findings are often dependent on region. With most of the refineries in Oz now dead, there's less variability in local stuff, and he majority of our fuels are not even refined here any more anyway. It probably depends more on which SE Asian refinery is currently cheapest to operate.
