Can you fast non-skyline Nissan VINS? Namely an S15?
6U900000S15019653
Also, can anyone help me with an RB26 engine number? I've been hunting around and found a source but this doesn't match them! Its supposedly from an R33 but I was trying to find out what year.
RB26065541A
Edit: It's just occurred to me, they probably made more than 2000 engines within 1997, so this would point to the engine being from a 1997 R33 V Spec?
Series 3 GTR 3rd February 1997 (Xenon Headlights) (V-Spec)
N1 Version Released: 3rd February 1997
R33 1997 Feb RB26-063xxx
Edited by James51
Hey guys can I please get a fast on these numbers: vin br32 006464 model # kbnr32rxfslmzg
Sold as v spec ii.
No results coming up... You got a pic of the blue plate?
Thanks.
6U900000S15019653
RB26065541A
^^ S15
You got the VIN for the R33 GTR?
Could help narrow it down if it's a N1 Version.
^^ S15
Thanks very much! Unfortunately I don't have the VIN from the R33. The RB26 is sat in that S15 chassis :) offer made and accepted today subject to mechanical inspection! Soooooooon
^^ S15
All good!
Oh I see what you did there... S15 with RB26 :D
For starters, does the block say 05U or 24U?
Haven't been able to take a look yet! It's booked in for a full mechanical inspection next Wednesday with Mercury prior to finalizing the sale.
Ok cool!
When you get the chance to have a look, post the number on the block in here.
  • 1 month later...
Hey gents, Looking to join the GTR community soon, Can someone please check this for me, wanting to verify if genuine v spec:
6U9000BNR34000751
Thanks in advance!!!
Loki
hi guys, could someone please check this for me:
BNR32-311488
thanks in advance.
V-Spec / V-Spec II?
    • Hi all,  I am in the market for an R200 longnose diff out of a Z31 300ZX, or S12 RSX, DR30 skyline, or similar, in a 3.9 ratio.  Preferably a late model one with the M12 crownwheel bolts.  The only easy to find advert for one of these was my ad back in 2007 when I sold it on this forum.  I sold the diff as I had sold the car it goes to, but as it turns out, after 18 years I got the car back late last year, so now I'm looking for the diff !  If anyone knows where to find a longnose R200 LSD with the M12 crownwheel bolts, drop me a line at [email protected] - Bonus paid if soomeone comes up with the original diff (stranger things have happened !).  Cheers   Ben D
    • Hi everyone, I used to post here a bit from 2004-2013, when I owned various Nissans, in particular my S12 RSX gazelle, which was sold in 2007.  As luck would have it, after an 18 year hiatus, the car found its way back to me last year, and over the past 11 months I have had the pleasure of restoring it with my kids.  One thing that I am after in particular is a 3.9 ratio R200 LSD for it.  I actually sold the one out of the car here back in 2007 , and it would be incredible if I could track down who I sold it to, so I can see how they have progressed over the years (and to be honest, to see whether I can get the diff back !).  Anyways, hi all and let me know "where are the R200 Longnose diffs all at these days ?  Cheers Ben D
    • Arms will be the same as the G35 or 350Z, but as above, there was a change in the lower control arm where it connects to the ball joint.  That said, you can remove the ball joint cone from your old ball joints and fit them to the new ball joints.  To be honest, I didn't think the ball joints themselves were different. The main ball joint is a bit awkward to replace, you really need to remove the steering knuckle to press out the old one.  Some people have used tools to remove it in place, but it just seemed too hard to get to. If you are going to press out/in that ball joint, then you may as well just replace the bushings in the LCA and the compression rod.  You can buy the compression rod bushing from Nissan, but the LCA bushes, you will need to go aftermarket. Much cheaper than buying the whole arm.
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
