All you auto drivers… I’ve got some auto trans questions for you all.
Does anyone here downshift when slowing down?
As in, foot on brake, put it in 3, then 2 on the auto shifter.
Does this cause strain on the box/gears?
Does this cause more heat?
For those of you with the upgraded valve body in their auto box…
If it’s in drive, I hear that the up-shift speed/feel depends on how much gas you are giving it.
So if just cruising along, the shifts are nice and smooth and if you are getting up it, the shifts are hard and fast.
Does it effect the shift at all if you were to say use the gear to slow down the car and say you have it in 2 while in the corner and you plant it, the revs go up and you just slip it in D while still gassing it… does it still shift like it should or does this confuse things for the ecu and it’s shift points?
What if any aftermarket trans coolers are you lot using?
Where is it mounted?
What did it cost?
Is it a DIY kinda job?
Anyone got a DIY gearbox oil change instructions or is it best to just buy your oil and take it to a shop who has a hoist and pump?
Anyone using Castrol gearbox oil? Which one?
How many litres?
Cheers
https://www.sau.com.au/forums/topic/128577-auto-trans-questions/
the point of an auto is to save you having to change gears, so i dont like to play around with it, but -
i have noticed that yes, just cruising along you dont feel or hear the gears shift, or even feel any diference in power. it just cruises and cycles through them.
if you gun it of the line, then yeah it changes very solidly. It hits 6750 and changes with a very hard feel into 2nd. No noise, its a relatively smooth transition, you just feel the power drop for a split second, then the revs drop, and bam youre in2nd and forced to the back of your seat again.
theres no point holding out to change it into 3rd, cos itll change at the same place anyway. If you wait for it to get to just under 7k, then slip it into third, you'll bounce off the limiter for a little bit. It takes a few seconds for it to change after you change gears.
Same as when you go from park to reverse, or reverse to 1st, it takes a split second.
i downshift manually sometimes GTST... but only at low speeds...
trans cooler was an item from supercheap for $100ish. its mounted on the drivers side of the front bar, in a mirrored position to the stock intercooler.. works well i think :D definately a DIY job.. very easy to install in about 2 or 3 hrs
as for gearbox services, i always take it to a mechanic..
will be able to comment on shift kits in a couple of weeks when my high-stall converter and stage 2 shift kit arrives :no::D
my trans cooler is sitting where the standard cooler was. there is group buy on with the davies craig auto cooler kits, its not really a group buy, its just offered at a reduced price of $118 with everything you'll need. i didnt like the way they suggested to mount them so i made up my own style, i'll post some pics tomorrow. and it is a DIY job.
i do downshift when stopping, and i do drop it into 2nd when cruising at 60 to feel some G's. i have been for 2yrs and my box doesnt slip or anything.
i used castrol dextron III with my oil change.
i'll be posting up a "how to" on changing oil and cleaning the filter inside the auto's (r33) so look out for it.
autos are great for drag racing, provided they can handle the power. Quick shifts, and if you have a trans lock (engages reverse and first at the same time, then releases reverse when you launch), you can get some crazy launches off the line.
If i need to brake in a hurry, ill shift down. If im going up hills, ill leave it in 2nd sometimes so it isnt constantly swapping cogs.
There are merits for downshifting (youll save your brakes, tighter around corners cos you arent just freewheeling etc) but theres no point reviving it out then clicking 2nd, then 3rd, then engaging O.D. The computer shifts at peak points anyway.
For the several weeks that I was in full automatic mode with the shift kit (upgraded valve body) I frequently utilised the engine break to mainly go around corners.
Constant gear changes will generate more heat but, proper service at appropriate intervals, good ATF & ATF cooler the trans should last longer & delay the inevitable.
Yeah thats pretty much right. The upshifts aren't harsh (except 1st to 2nd gear change when driving off slowly from idle) whether on the gas or cruising but, you do feel more push back into the seat at full throttle compared to stock.
To begin with the auto ECU isn't always predicatble especially depending how far you got the pedal down when in D, coz things can get hairy when cornering in 3rd (or O/D) & it decides to kick down a gear :laugh:. But, normally if foot is firmly planted in 2nd & then up-shift it will go into & stay in 3rd.
    • Back again. I returned to Japan in Jul/Aug to spend time with the car on my birthday and remind myself what all the sacrifice and compromise is for. It happened to line up with the monthly morning meet in Okutama, which I have been wanting to go to for a long time. It's a unique event at a unique spot with really rare, interesting, and quirky cars. It's where all the oldheads and OGs gather. The nighttime scene at DKF certainly has its place and should be experienced if you're into cars, but there's too much bad attention and negativity around it now. IMO the better time is Sunday morning at DKF or Okutama; it's more chill and relaxed. I'm glad I was finally able to go, but not sure it's worth the drive from all the way from Nagoya immediately the day before, unless I was already staying in Tokyo for the days right before the meet, because you have to wake up quite early to make it in time. Funnily enough though I didn't drive the car all that much this trip because it was just too damn hot. While there were zero issues and running temps were nominal and the A/C was strong, RBs already run crazy hot as it is. Sure, it took it all like a champ but something about driving these cars in the ridiculous heat/humidity bothers me and makes me feel like I'm asking too much of it. I'm just me being weird and treating the car like a living thing with feelings; I'm mechanically sympathetic to a fault. Instead I was mainly driving something else around - a KX4(silver) 2001 X-Trail GT, that I acquired in May. There's a few different flavors to choose from with Xs, but visually it's the Nissan version of the Honda CR-V. Mechanically it's a whole different story as this, being the top-trim GT, has an SR20VET mated to a four-speed auto and full-time AWD! It was a very affordable buy in exceptional condition inside and out, with very low mileage...only 48k kms. Most likely it was owned by an older person who kept it garaged and well-maintained, so I'm really happy with how it all worked out. It literally needs zero attention at the moment, albeit except for some minor visual touch-ups. I wanted something quirky, interesting, and practical and for sure it handily delivers on all three of those aspects. I was immediately able to utilize the cargo and passenger capacity to its full extent. It's a lot of fun to drive and is quite punchy through 1st and 2nd. It's very unassuming -in the twisty bits it's a lot more composed than one would think at a glance- and it'll be even better once I get better tires on it(yes, it's an SUV but still a little boat-y for my liking). So...now I have two golden-era Nissans in silver. One sports car and one that does everything else; the perfect two-car solution I think👍 The rest of the trip...I was able to turn my stressed brain off and enjoy it, although I didn't quite get to do as much as I thought. I did some interesting things, met some interesting people, and happened into some interesting situations however, that's all for another post though only if people really want to know. Project-wise, I went back to Mine's again to discuss more plans and am hoping to wrap that up real soon; keep watching this space if that interests you. Additionally, while working in the tormenting sweatbox that is the warehouse, I was able to organize most of the myriad of parts that my friend is storing for me along with the cars, and the 34 has a nice little spot carved out for it: And since it can get so stupid hot in there, that made it all the more easy -after I was standing there looking at the car and said 'f**k it'- to finally remove all the damn gauges that have mostly been an eyesore all this time. Huzzah. The heat basically makes the adhesive backing on the gauge mounts more pliable to work with, so it was far less stressful getting this done. I didn't fully clean it up or chase the wiring though; that will happen once I have the car in closer possession. Another major reason to remove all that stuff is to give people less reasons to get in my car and steal s**t while it's being exported/imported when/if the time comes, which leads us to my next point... ...and that is even though it's time in Japan is technically almost up since it's a November car and the X would be coming in March, I'm still not entirely sure where my life and career is headed; I don't really know what the future looks like and where I'm going to end up. I feel there's a great deal of uncertainty with me and as a result of that, it feels like I'm at a crossroads moreso now than any point in my life thus far and there are some choices I need to make. Yes, I've had some years to consider things and prepare myself, however too much has happened in that time to maintain confidence and everything feels so up in the air; tenuous one might say. Simply put, there's just too much nonsense going on right now from multiple vectors. Admittedly, I'm struggling to stay in the game and keep my eyes on the prize. So much so in fact, that very recently I came the closest I ever have before to calling it quits outright; selling everything and moving on and not looking back. The astute among you will pick up on key subtext within this paragraph. In the meantime I've still managed to slowly acquire some final bits for the car, but it feels nice knowing there's not much left to get and I'm almost across that finish line; I have almost everything I'll ever want for my interpretation and expression on what it is I think an R34 should be. 'til later.
    • Thanks for that, hadn’t used my brain enough to think about that.
    • Also playing with fire if they start to flow more air down low than what the stock twins can. It's not even up top you need to worry, it can be at 3000rpm and part throttle and it's getting way more flow than it should.
    • Any G40/1000 or G40/1250 results out there?
    • You still want a proper tune on the stock ECU though. Stock tune + stock ECU with GT-SS/-9s is probably playing with fire if you're running more than stock airflow/power.
