its a bastard finding rims, and to rub it in those volks were perfect for me and a damn good price but i called a few places and they said that they would never drive on a cracked rim. i figured that my mum would have a heart attack if she knew i was driving on a cracked rim. oh well maybe ill find something else
https://www.sau.com.au/forums/topic/12878-my-new-wheels/#findComment-258328
