got the car back. it feels the same. spins way too much for it to be locking. the light comes on so the puter i can only assume is doing what it is supposed to. i guess the next step is to work out the how pump gets power and try and hard lock it.
  • Replies 68
paul, as I said before, watching with eager eyes.
Ps: 350 is a lot of money to just remove the diff.
It's actually easy to remove the diff yourself. The difficult thing is changing the centre - that needs alignment. My friend got his centre changed for 150$
That switch sounds like the goods.
That's why I was asking you before about wwhat you thought of the performance of your diff.
If I do a burnout, it will spin both wheels. although, one won't be spinning much, but it does spin.
But just generally, like very quick twisty driving, the diff never locks. I doubt this is how it's meant to perform.
I have a friedn with an r32 gtst with a brand new stock diff - was replaced under warranty. I'm 100% sure it's stock, because i saw the workshop open the parts, all in the nissan boxes and all.
It actually feels quite tight. Obviously not clunk clunk chatter chatter as you go in a tight corner, but if you press the gas a bit more, you can feel it biting.
yeah mine used to perform kick ass
we've seen it lock solid for 30 seconds odd
and leave a big darky on the street
so i did lock hard as previously
and it used to glide when going sideways as well
so it did have the capacity to as well
i think it could be a case of the pump is lacking oil pressure
or strong pressure so it doesnt lock strong enough
a bit of wind but you can see it smoking from both sides
and it left double wheel'd darkies
that was feb 2006
when i had just completed the wiring look hack to make it work with the powerfc
it was the first time i actually had it not erorr (a-lsd come on normally) with the powerfc
so i had to test it and it locked awsome
the guy at northern differentials who opened it up said that the diff is at the mercy of the pump. it needs good pressure to make it lock. if the pump or puter doesnt do whats its supposed to, then it wont lock very hard he said. he was very surpirsed when he opened it up. he said its a very strange diff
actually i am confused. maybe just pulling it out, flushing and cleaning it and putting it back has fixed it? the car seems to be really nice gliding when i bag it up and it seems to really swifting sliding when its lost traction. i did a bit of a curry run today on the street out the front of work and walked past it just before and its left two perfect darkies on the road. so its locking it seems
ill need to do some more testing
next step is to see what pressure is coming out of the pump when it locks
ive also noticed greenline list all their aftermarket lsd's as not suitable for active lsd models
NISMO GT LSD Pro 38420-RSS15-B5 / 38420-RSS20-B5
(Differentials) ¥101,640
Selective type. 1.5 or 2 way. Kit includes, LSD oil, side flange, oil seals, gasket ring gear bolts.
Not suitable for use with vehicles fitted with active LSD.
did some more fiddling today. we found the pump gets 12v at startup and then 4v at idle. we only saw this once and was unable to replicate it. we tried to watch voltage when the system went into slip but couldnt pick up any signal (not sure why). we ran a 12v off the battery directly via a relay switched from in the car and u can hear the pump come on and lock. it seemed to be heaps better and actually spin both wheels. but now im not so sure. the pump is making a wierd noise. tomrrow we'll pull apart the oil lines and see how the pressure is flowing around. maybe its too low. but the override switch is cool
i think the next step is to lock it via the switch
and then plonk it on a dyno to see what each wheel is doing
i suspect the pump is ceased or not strong enough (really tired)
completed the override button today.
a proper button with led to indicate when on.
its protected by a 30amp fuse and relay system
so i can choose between computer controlled pump or manual run.
i think the pump is preload system and isnt used when the car is actaully spinning. cos if i run it normally when the car isnt moving u can hear it come under pressure and load by the tone of it. you can see the lsd fluid level drop when the pump runs (right hand side of the boot). so it appears the pump is ok. i might do some testing later tonight when its dark. im going to pressurize it and then turn the pump off (well back to normal puter mode) and do a burnout and see how it goes. i think having the pump hard locked on whilst doing burnouts or "slipping" makes it worse. i think a hard pressurize before a burnout and then drop it to normal mode may yeidl the best results. will also try and plonk it on a dyno in the next day or so to see whats going on in the rear end
ok did some testing on some private roads.
1) sideways
come up to a corner in 2nd gear
leave puter in normal mode
turn the corner and boot it, lots of wheelspin and it carries on like usual
slip comes on and it operates normally.
2) takeoff
come up to a stand still. stop.
turn on diff lock. take off
lots of axle tramp and a bit of double wheelspin
a big improvement for traction
3) rolling clutch dmp
rolling. turn on diff lock.
boot it. a little bit of wheelspin
it feels to bring the car around a bit more and direct it properly
4) roundabout
come into the roundabout
turn on diff lock while rolling
boot it. a bit of a double wheel spin and glide out of the roundabout
so far a big improvement
just not sure how safe it is for the pump
or how long it will last like this (being hardset to 12v on demand)
did another test today
come up to an intersection
turn on diff lock
turn the corner in 2nd
give it curry
nice double wheel spin :rofl:
im going to look into getting the hydraulic fluid line for it braded so that it dosent rupture under pressure and also an oil pressure guage on it so it doesnt go bang from excess pressure
ive noticed when the pump runs for more than 2 seconds and the computer doesnt expect it to run it failds. it must have a pressure sensor and its picking up pressure when it isnt expecting it and thus fails. hopefully i can work out an override relay switched for the pressure sensor
have ordered a poor mans auto guage oil pressure guage
with elec sender so i can monitor pressure in the diff
im worried it might get mega high when its hard locked at 12v
there is a pressure sensor switch attached to the side of the pump
if it detects pressure it turns on a relay to the puter.
the puter must check this in real time and fail if it see's pressure when its not in slip mode. so we'll be attached this pressure switch into a our relay loom so its ignored when i hard lock it, this will prevent the puter failing when driving normally. cos i have to reboot the car when a-lsd fails, just a bit annoying.
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
