  • Replies 128
Posted Images
I've decided to sell my flush fitting boot and put my Cf Boot lid on since it fits so freaking nice. I've got a gtr adjustable wing on the way from slo25L . Im going to be painting the wing Orange, should look nice with the carbon end inserts.
Yeah good aint it! Judges where so impressed buy the flawless bodykit/panel work.
Congrats.
Normally I am not a fan of this kind of standout colours in Skylines but the work you've put in is mint.
Now get some nice rims on there - just please don't put some cheap chromies on it!
My plan is to attach some lieghweight offset drift rims, in a black sort of finish.
The money is going towards the motor atm as I have a pretty nasty combo linned up.
duno if you've thought of this but i rekon it would top off the black look if you blacked out the rear quarter windows like the 180 boys alwayz do, would complement it will. also love the shinny black on the interia very well done most of the painted interias look tacky and out of place that looks sweet
Thought I would share the first pics of adding a gtr vspec wing , wings not bolted on yet.
Just getting ready for paint, plans are to paint the wing orange and the adjustable blade black.
I have a set of wheels and coil overs coming next week :rolleyes:
They are only there for the momment. Im going to customize the whole front bar soon.
You can purchase the lights from most automotive stores all they are is clear tralier lights. if you choose to use these buy 21watt replacement bulbs otherwise it will cause your indicators to blink really fast. I think they were about 13$ each .
Hope this helps mate
    • Ok thanks..that was my second question if i can somehow bypass this even with Nistune(that is all i have right now...aparat from stock ECU. So with some aftemarket it can by "bypassed" or make it work?  I know there is Link or Haltech (mainly used). We have ECUmaster here so i will gather some info about it.
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
