Hey guys,
my R33 gt-st has some faded spots on the steering wheel. i think the guy who had it before me had the brilliant idea of using armour all on the leather! :S
anyways, i have tried meguiars rich leather on it and it cleaned up some of the faded spots however, there are still some spots no matter how many times i apply the rich leather, the faded spots still return.
anyone know how much it would cost to get the leather re-done on a steering wheel?
cheers
It's very expensive. From other people's experiences on here, it's around $200 for good leather.
I don't think it's possible to fix. Has the leather worn through that top shiny stuff?
I tried every single thing possible on one of my seats in my other car. Didn't work.
it will probably cost you more than a nice aftermarket steering wheel.
prices will vary and dont forget you'll be steering with a spanner for a few days while they replace the leather on your steering wheel :)
I can't get mine clean either. I just thought id mention to be careful what you use. You dont want your steering wheel to end up really slippery.
Good point Rob. A few years ago I was cleaning my motorcycle and absent-mindedly armorall'd the vinyl seat... I found out the hard way, but managed to keep it upright! >_<
hey mate
you can buy paint that is actually for carpets, rubber, vinal etc.
from memory it actually works for leather too...
you simply spray it on like normal paint but it sticks to the leather and flexes
a mate of mine used it and it just looks like the normal steering wheel...
check out the paint section of repco/supercheap etc.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
    • OK, if it idles at 1000+ with the AAC, its not an idle airflow problem. The cold start valve just gives extra air when the engine is cold, but you have enough air without it to idle at 1000. I think you are back to a fuel problem, sorry. Can you see the fuel pressure staying constant or does it drop as the revs drop to a stall?
