Hi,
Just wondering if anyone knows what the legal strength of the Xenon Blue bulbs allowed on our roads.
ie: 4000k 6000k
Any help would be great
Cheers
Someone must know???? :)
It's not a matter of colour, you can't have non-levelling xenons.
I will tell you now however that 4300k being natural light I would go with the 4000's.
I had 6500k before and they weren't too blue (only slightly)... but if you want to keep the fuzz away 4000k will look whiter.
in the phillips range the blue vision is the bluest legal. the crystal and diamond vision aren't. the bulb has to be adr approved. so there may be some the same colour as blue vision but not be legal. i think blue vision are about 4000k. the crystal vision are 4300k.
the other thing is that the blue vision are only the same strength as a standard bulb, and crystal are dimmer. it also depends on if you are going to colour or ability to see. if you want to be able to see well then go phillips 50+. they are much brighter than standard bulbs.
Edited by mad082
commonly 'xenon' just means a halogen bulb with xenon filler gas rather than another noble like argon. xenon lets them wind the filament tighter and produce a brighter, whiter light for the same wattage.
An HID conversion is upwards of $1k, so legal issues aside it's out of the price range of most people.
word like a motherf**ker. ANY bulb which is blue tinted MUST cut light transmission. I've only tried 1 brand of "cool white" globes and the lighting quality was abysmal. Yes it was "cool blue" but it was also about 1/3 as useful as a regular globe. I ripped them out and put Plus 50's in, WAY better.
Anyone who uses blue tinted headlight globes is a fool. Tinted parkers so that they match the colour of your headlights is one thing but for safe forward illumination you'd have to have rocks in your head to go backwards in light intensity.
Kinks and mad082. Spot on the money. When it comes to lighting, it is one of my interests. Very well explained.
I will just add a couple things. White gives the illusion that it's brighter. E.g. if you get a globe and give it 6 watts, it'll have a yellow dull glow, then whiter, whiter whiter as you add more power.
That's why peopel put the white bulbs in and think the're brighter (disregarding that people think white looks nicer).
Secondly, a very good way to increase lighting is to relay the stock headlights. Mine measured 11.1 volts before relaying them. at this voltage, they only emit about 60% of the potential lighting. After relay, they get 13.8 volts. noticeably brighter.
Yep, relaying is also a good trick. I haven't measured my lights but if I put Plus 50's in and they're still not bright enough I'll look into it. I'm still running the factory original globes AFAIK (and my headlights could use a polish!).
I'm running both 6000k HID's for my low beams and jsut philps crystal visions for the highs. I'm not sure if it's so much the colour that woudl distract the police at first (taking into account it's not overboard) but i woudl say it's mor important if you do a HID conversion to make sure your lights are properly angled. My HID's are so bright and when i first installed them alot ppl flased ect...... now after beign readjusted they seem fine and i hardly ever get flashe. No police trouble...... btw i find the phlips crystal visions look bluer then the 6000k HIDs.
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
