My car idling a bit high around 900rpm even when warm (air con off).
When aircon on, every time the compressor kicks in to cool air, the rpm will drop to 500rpm, almost stalled the car, then somehow the engine or the ecu managed to keep it up to around 700-800 rpm again....
Is this caused by the same TPS or something else? My car has automatic ECU (was an automatic now converted to manual). Should I change to manual ECU?
  • Replies 42
What I also noticed especially when the car was cold is that when the car was in the flat spot area of acceleration it would spool the turbo up really easily, the boost guage would sit on 0psi, the car would be slightly hessitating and feeling like some thing is holding it back then all of a sudden it would take off.
So possibly it was running lean on light throttle?
It drives like a totally different car now. I think it feels a little more responsive on light throttle and feels so smooth.
well I know what I'm doing tommorow! :)
I get exactly the same thing. The flat spot at about 2k revs, just before coming on boost! Plus my car is a bitch to start on a cold morning.
Would this fix the occasional staling in reverse as well?
Yay, I so can't wait to do this! I thought the flat spot was just cause it was cold and the engine is getting a bit old! I had the same thing with a pulsar I had many years ogo. Plus one of my mates gets the same thing on his CC lancer. I don't think it will work on the lancer though 'cause it has a carby.
Cheers Joel!! :)
Just one thing: if so many ppl have this, does anyone know if it's done for a reason. I.e. to reduce engine wear when cold? Or is it just wear & tear that causes it to wind up like this?
My R32 gtst does EXACTLY what kabab describes his does in the morning. I put it down to the cold start sensor thing that joel had a thread about ages ago, where he cleaned it out etc.... because exactly as soon as my temp guage gets to half way (as in the car has warmed up) the hesitation, no light throttle feeling goes away with a splurge. It will have no light throttle, then vroom, all is normal. My car is standard, apart from the apexi air filter. I dunno, but its still going, so I'm happy :)
Steve (aka toy_R32, aka steve_R32) :)
There is iactually 2 seperate TPS's on the skylines. The oone for engine management indicates closed throttle and 3/4 throttle only. The other one is for an automatic transmission, and this one is a variable resister/potentiometer. Both are in the same housing.
Another thing that can cause a sputter on first opening the throttle is a minor air leak, such as from a PVC valve.
Interesting, I might have a quick check over mine.
I did notice when I pulled the PCV Valve thing that goes to the Turbo Inlet that there was like some sort of wire bottle brush filter looking thing in the piping?!?! Is that normal?
Yeh, I had a similar thing when a tiny vaccum hose come off the fuel rail or somewhere around there. Idle went up, car hesitated, and the on, off throttle was terrible banging the slack in the transmission. Pulled the AFM out and cleaned it, pulled the plugs, all good, checked the Throttle Posi Switch, I was stumped and frustrated. Then whilst looking over the bay, noticed the little hose not quite sitting securely on the little pipe off the fuel rail, put it back and car was perfect again.
BTW, anyone know what the little canister normally mounted on the RH strut tower is for (the one with the boost restrictor) my car doesn't have one at all, must be bypassed.
Gumby...
your problem would not only have been an air leak, but also high fuel pressure down low. That hose takes manifold pressure to the fuel regulator, high vacumm (idle) means lower pressure.
You have adjusted it to high then daVE.
I had the screws with slight tension on them and tapped the TPS with the screw driver slowly until I heard the rev's drop to normal idle then i tightened it up.
It may take a couple of goes but you will get the feel of it.
does the TPS actually come off or do you just turn it???
i took off the screws and could not get it off. didn't want to force it so i just had a play but flat spot still there.
pelase explain in more detail what it is you are doing...
You don't pull it off. Re-read the description of what I did.
There isn't really much more detail that I can explain it in. Have a re-read.. Even read it and then write it in your own words if it will help you understand it.
I had another fiddle with mine to try to get it just that little bit better. I noticed when I tried to fiddle with it when the car was warm it was extremly difficult to get it right. When the car was cold it is a lot easier.
Strich9.. I would notice a flat spot anywhere in the rev range if i would really really really slowly feed the throttle on from nothing. Then all of a sudden it would take off. I would also notice the boost guage looking like it was making boost but I wasn't actually going anywhere.
    • That's not a transistor --- it's marked ZD1 which makes it a zener diode. As to what the breakdown voltage is, not enough there to divine.
    • Hi all, Long time since I've posted here. Looking for some advice on what I can remove to further identify the cause of my issues.  I can move the passenger seat forward and back but the knob used to adjust the seat angle is pretty much free spinning, there's very little resistance.  Removing the side cover I can see that the chain is intact but the shaft for the adjustment spins without the gear attached to it moving.  What's my next step for disassembly here? Is this a common fault? Just being a little cautious as I didn't want to start removing bolts for a spring to fly out or something equally as stupid.  Cheers
    • The incentives are mostly the same, yes. Ethanol is cheap compared to the cost of doing 98-100 RON with crude oil alone. 87 to 93-94 AKI all with E10. In 2020 Canada mandated E10 as a part of their "renewable fuel standard" and is supposedly going to go to E15 in 2030. In California where there are only 8 refineries with two threatening to shut down next year it's been over 20 years now of E10 and 91 AKI maximum because there's just not enough refinery capacity or crude oil supply relative to the demand for premium unleaded fuel. And CARB's low carbon fuel standard means functionally none of the diesel available at the pump is made from crude oil anymore. It's almost all entirely 20% biodiesel blended with 80% renewable diesel (hydrotreated vegetable oil) now. The number of gasoline vehicles that support E15 or higher ethanol concentrations is surprisingly low, I can't imagine it being wise to play tricks like this without flex fuel sensors in most of the fleet.
    • It's almost certainly the same as the one next to it. Have a fish around amongst these hits https://www.google.com/search?q=surface+mount+transistor+m33&sca_esv=9cb49794e0b2005d&source=hp&ei=2vJ5aNjTB7Kw0PEPldnS8QM&iflsig=AOw8s4IAAAAAaHoA6qkfmF6XcygtrZ4Vu9f92NXF_RFd&ved=0ahUKEwjYqIPP7MWOAxUyGDQIHZWsND4Q4dUDCA8&uact=5&oq=surface+mount+transistor+m33&gs_lp=Egdnd3Mtd2l6IhxzdXJmYWNlIG1vdW50IHRyYW5zaXN0b3IgbTMzMgUQIRigATIFECEYoAEyBRAhGKABMgUQIRigAUjKCFAAWABwAHgAkAEAmAHfAaAB3wGqAQMyLTG4AQPIAQD4AQL4AQGYAgGgAuYBmAMAkgcDMi0xoAfMBLIHAzItMbgH5gHCBwMyLTHIBwU&sclient=gws-wiz
    • South Australia, which is hardly as far behind as the rest pf Oz makes out, and who is also not a paragon of progressiveness (read that as over-legislation) in the area of vehicle standards, has this to say on the subject: Adjustable coil-over suspension Aftermarket adjustable coil-over suspension components are suspension units that incorporate an external thread on the main body and corresponding threaded spring saddle that allows the vehicle's suspension height to be varied. If fitting aftermarket or coil-over suspension components you must submit an Application to modify a light motor vehicle form and a report from a light vehicle engineering signatory (LVES).
