  • Replies 58
It wasn't that difficult, but then again it's a bit of a half-assed job... Here's how I did it and prolly isn't the best way. Wasn't expensive though.
You need a clear panel for this
[*]get the thing off (4 nuts)
[*]remove any silver paint from letters so they are clear
[*]cut the back out in the shape of a letter box (you'll never get it open as it's sealed with goo, grrrrrrrr!)
[*]get some translucent red self adhesive vinyl and stick to inside of panel (mine needed 2 thicknesses to get the colour right) - £free
[*]clean it well and carefully mask letters and black bits (masking the letters took a razor sharp knife and a lot of time)
[*]get (right colour) spray paint and plastic primer - £12
[*]prime, spray to a good thickness
[*]get a neon tube, mine's for a PC case but is a bit short, and fix inside - I used a hot-glue gun near the ends. - £13
[*]test
[*]seal up with whatever you like
[*]tag transformer wires onto tail light circuit
[*]fix it back on
[*]connect up
[*]grin! - £priceless!
[/list=1]
Hardest bits were masking the letters and getting the right colour paint - the QM1 I had mixed was no where near the QM1 the car's sprayed in (apparently there are at least 2 QM1s...).
Cost just over 25 quid ($65 ish). Bargain.
https://www.sau.com.au/forums/topic/12932-has-anyone/page/2/#findComment-254975
for r32's this light was a factory option offered by nissan. in the r32 factory optional parts catalogue it was called the "rear finisher" and was sold under the following codes according to body colour.
5NG03~5NG07,5NG09,5NG10
the price at the time was 33,300 yen. i went to tokyo nissan last week to ask for one for my friend. but they ceased production quite a while ago in 1995.
https://www.sau.com.au/forums/topic/12932-has-anyone/page/2/#findComment-277086
guys.... i just got pulled up by the coppers. "you arent allowed to have allowed to have any blue lights coming from your car. (its green) the only people allowed to have blue lights are police cars" "it came with the car!" "remove it"
i was lucky to get away with it, because the car was just imported. the fine is $75 and one point.
https://www.sau.com.au/forums/topic/12932-has-anyone/page/2/#findComment-318082
AtomicBomberMan
what state are you in, im in WA and the new rule here is that there is not allowed to be anything like on the bonet, but you can have any colour underglow you want aslong as the globes themselve are not visable. So the glow is fine. I had blue LED windscreen washers to and they are illegal because they are visable but underneath fine...Weird!!!!!!
Taking pics tonite so ill have them up on sunday for you guys to check out
cya
https://www.sau.com.au/forums/topic/12932-has-anyone/page/2/#findComment-320003
G'day Moschops
Can I ask, could you explain the following steps. I'm having a lil trouble trying it
How'd you remove it? scratch it off?
How'd you cut it? looks kinda fragile thats all.
Hmmm, any advice on where I can get this from?
May I ask, what black bits are you referring to? I presume you simply used that white marksing tape is that right?
Please advise as I reckon your car looks awesome. Thanks heaps in advance.
https://www.sau.com.au/forums/topic/12932-has-anyone/page/2/#findComment-321674
    • Hi all,  I am in the market for an R200 longnose diff out of a Z31 300ZX, or S12 RSX, DR30 skyline, or similar, in a 3.9 ratio.  Preferably a late model one with the M12 crownwheel bolts.  The only easy to find advert for one of these was my ad back in 2007 when I sold it on this forum.  I sold the diff as I had sold the car it goes to, but as it turns out, after 18 years I got the car back late last year, so now I'm looking for the diff !  If anyone knows where to find a longnose R200 LSD with the M12 crownwheel bolts, drop me a line at [email protected] - Bonus paid if soomeone comes up with the original diff (stranger things have happened !).  Cheers   Ben D
    • Hi everyone, I used to post here a bit from 2004-2013, when I owned various Nissans, in particular my S12 RSX gazelle, which was sold in 2007.  As luck would have it, after an 18 year hiatus, the car found its way back to me last year, and over the past 11 months I have had the pleasure of restoring it with my kids.  One thing that I am after in particular is a 3.9 ratio R200 LSD for it.  I actually sold the one out of the car here back in 2007 , and it would be incredible if I could track down who I sold it to, so I can see how they have progressed over the years (and to be honest, to see whether I can get the diff back !).  Anyways, hi all and let me know "where are the R200 Longnose diffs all at these days ?  Cheers Ben D
    • Arms will be the same as the G35 or 350Z, but as above, there was a change in the lower control arm where it connects to the ball joint.  That said, you can remove the ball joint cone from your old ball joints and fit them to the new ball joints.  To be honest, I didn't think the ball joints themselves were different. The main ball joint is a bit awkward to replace, you really need to remove the steering knuckle to press out the old one.  Some people have used tools to remove it in place, but it just seemed too hard to get to. If you are going to press out/in that ball joint, then you may as well just replace the bushings in the LCA and the compression rod.  You can buy the compression rod bushing from Nissan, but the LCA bushes, you will need to go aftermarket. Much cheaper than buying the whole arm.
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
