Come on fella's i need a bit of a reality check here. Who puts the most KM's on their Skyline a week? GTst and GTR?
Just curious. I seem to have gotten it in my head that these are fragile little cars that need protecting!! LOL!! And cant cope with general useage, which i know isnt true... Im still thinking of buying a cheap run around as a second car when i have to go back to a 40KM round trip to work and back early next year... ( at the moment im renting within walking distance of my work)
So give it to me..... I can take it.... :wave:
https://www.sau.com.au/forums/topic/129490-number-of-kms-per-week/
Heya, I have been using mine for work and general running about, totals about 350km per week, been a good car when I keep it serviced. But I have been thinking of buying a rolla' as a work car and keeping the skyine for weekends - done the maths and it should work out cheaper :wave:
Oh' its a R32 GTS4...
Man, I abuse my car in terms of usage.
I average around 700 a week in a 33 gtst.
Alot of highway/freeway type driving and I usually get around 12l/100kms.
Living 60ks away from your workplace is bad!
same boat man,
cept my workplace is all over qld- so at times i drive like 1200kms to work lol.
Prob average maybe 550-650km per week tho..
I car pool of sorts, so only take the 53km return trip to work 2-3 times a week. Throw in a little drive on the weekends.... fill up every 2nd week. (edit... 1.5 weeks LOL)
Edited by Tangles
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
