Hi All,
Quick question on the gates timing belt sold for the skylines, the blue coloured one. I know a lot of people are using this product out there.
I recently changed my timing belt to the gates brand and now have a slight humming sound coming from the belt at low rpm or idle.
The mechanic did explain that if the belts are tensioned too tight that they will hum, but as I was with him while the work was being done I don't believe that the belt was over tensioned. We actually went to a lot of trouble in getting the right tension. The old though was worn and very loose.
Anyway, has anyone had the same experience using the gates belt. Does it settle in and the noise go away?? Is that the way they are?? Or should I go to the trouble and losen the belt off a touch and see what happens??
Any ideas?? I would be greatful.
Regards,
Paul.
https://www.sau.com.au/forums/topic/129688-gates-timing-belt-r33/
I got one of these; as do quite a lot of owners on this forum - the humming noise is normal from what everyone says. It's not a constant hum more like an intermitant hum that happens every "cycle"
yep can vouch for that happens to me same belt
Thanks Guys,
Appreciate the comments, but has anyone actually tried adjusting the belt again to see if the noise improves?? Or goes away.
Also for those of you mechanically minded did anyone notice how the belt fit onto the cam gears. Did the belt sit flush into the gears or was there a bit of play.
The old belt that had years of wear had a fair bit of play and the new one while a lot beter still has slight play.
I'm thinking that worn cam gears could be a factor in the noise.
Any thoughts.
Paul.
I did one of these in my 33gtr and had the same problem. I readjusted the belt three times in total as the first time I think it was a little tight, and it did quieten down as I loosened it off, though I went too loose one of the times just to see if the noise went away, it did'nt.
I have had it in for about 5000kms and it is pretty much gone now, though you can still hear it if you are looking for it. Only after the engine is at running temp of course.
hope that this is helpful.
Oh, forgot to mention I did cams a adjustable gears at the same time, so the belt fit pretty snug in the gear teeth, and the drive gear was not worn. If your gears are worn it is pretty easy to tell by the lip as the belt dose not cover the complete gear and only weres on about 95% of the face of the tooth.
Edited by mark morris
Thanks for the info, really appreciate it.
Pity you experimented 3 times in getting things right.
I think I will wait until I reach 5000k's before tackling the belt again, and if I do I will get the gears changed as well, therefore I make the job worth while.
Paul.
Hi All,
Regards,
Paul.
had the same problem..on close inspection of belt found small threads that bridged belt teeth causing humming sound when running(poor quality) ..these belts are crap imo ..nothing wrong with genuine part price or quality... i fixed mine by throwing it in the bin and using a genuine belt
The blue gates belts promoting tripple the strength of stock. They are crap chuck it in the bin get yourself one of these babys Nissan 13028-20P25 will fix all your problems. Save yourself embaresment at the lights mate.
why is it better than the other if its just a stockie? what part number does this get you then 13028-20P10?
thanks
Dont know mate. Atleast its quiet! That gets you the new one it must be marked in the catalog. just red tape i guess.
  • 4 months later...
How much is the genuine nissan belt??
I just ordered gen nissan one - $60!!! w00t!!!
I actually asked on the 100k service thread if anyone could tell me why I should buy an aftermarket belt as opposed to gen one but no real responses..... I was gonna get a Gates or Nismo belt but couldn't justify nearly $400 for the Nismo one..... Is there any real difference btwn gen and aftermarket???
There's nothing wrong with the standard Nissan timing belt - dead quiet at idle and has a 100,000k change interval, I got mine for $85.00 off eBay, Nissan sell them for around the same.
That being said, my R33 had a very annoying whirring at low revs when I first bought it, and it apparently had a new, genuine Nissan timing belt.
I eventually took it to Nissan and had them replace all the belts and tensioner/idler pulleys as part of a major service...It turned that the tensioner bolt was slightly bent which was causing most of the 'hum' or whirring at idle, it's perfect now - might want to check this out if you're having this problem.
Awwww, $60 directly from Nissan?!
....damn ebay (or damn my stupidity for assuming Nissan would be pricier, they usually are!!) :P
Yeah - direct from my local nissan..... even with the SAU discount Lincorp still wanted $94 so it really does pay to ring around and apply a little pressure!!! I think it depends on the parts..... sometimes nissan is more exy..... sometimes not!!!
I was quoted $220 for a belt..... hmmmmm..... dunno if he thought I was just a dumb chick or what but you''ve only paid $20 (or so) more than me so I wouldn't stress.....
  • 3 months later...
Hi all..
throw your Gates away! I put one in after rebuilding my engine myself. I made sure my belt was not too tight and it still makes the whinning noise.... It doesn't matter what tension you put on these belts, most of the time, you will experience this humming with these belts...
I've done 25,000kms on this rebuilt engine and it still humms.. I've loosened the tension twice with no improvement.
Although the general rule of thumb would tell you that tightening a belt too much can make it whine, this is not the case with these belts.
If anyone trys to tell you that your whinning is because your Gates timing belt is too tight, then they obviously have never used one!
Just my 2 cents... I've since put in a Greddy belt and it's quiet as... very happy... only $114 too!
    • For these last 7 years of ownership, I've always had to use a small scissor jack under one of the front tow hooks to raise the front just enough so my low-profile jack fits under to reach my subframe jack point. I'm beginning to get annoyed of always having to do this. Are there any lower low-profile jacks that fit under the gtr lip on a dropped car?
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
