Need to either clean or replace my air filter, atm i got a HKS mushroom one on that is really dirty, but i heard it isnt too good and i should jus scrap it and buy a new apexi style one.
Wat do u guys reckon, should i jus clean the mushroom one or buy a new apexi style one.
P.S. is there any difference b/w buying a real apexi or a fake $40 one that they sell at autobahn?
https://www.sau.com.au/forums/topic/129718-what-to-do-wit-air-filter/
I have a hks musroom too, it was filthy. It went all crumbly when I took it out. Just replace it, costs $50 from justjap, genuine HKS too.
This is wat i am afraid of,
Should i get a real apexi one or just a $40 copy if i decide to replace it?
Just use an Apexi panel and get the stock airbox back on unless you need to run huge power. My GTR runs the same size panel as the GTSt's with 260rwkw so decent power is not a problem, it just has more air inlets to the box and that can be corrected with a with of imagination and cutting and ducting. Plus you can then run a decent front mount without defect.
Why would you clean an HKS filter element? They are a single use throw away item.
Purchase a new element for it as mentioned above, cost is around $50, and you then have a brand new filter.
Just Jap has them on their website
One thing you will notice though is that the hks pod makes a lot more noise than the apexi. Therefore, theoretically, it should flow more.
However, this would be at mega power levels. At stockish power levels, any extra flow won't give more power.
On a 1000kw car, it probably would.
Completely wrong.
Just because it makes more noise doesn't mean it flows more. It could be increased turbulence causing the noise, or greater restriction, ie blow a certain mass(at the same temperature) of air through 2 vastly different sized orifices in the same amount of time....the smaller orifice makes much more noise due to increased turbulence and restriction so more effort or pressure is required to do the same job resulting in a less efficient delivery. Equate this to the smaller filtering surface area and the turbo dragging the air through. Also in terms of sound pressures, if noise is coming out that is causing a negative pressure wave in the intake. Bottom line, HKS filters are complete junk. There was a HKS panel in my GTR and the amount of sediment lying in the bottom of my airbox after the filter was worrying.
Correct that stock power levels would be around the same but better flow means better response. The important thing though is clean air and HKS clearly fails that criteria from both my personal experience and others' testing.
What the testing shows is the boost produced by the car with each filter, of which the Apexi and then Blitz were the best (highest) with SARD and HKS the worst, and the filtering ability for the medium used for which the Apexi performed best and the HKS about the worst. I have another similar study on my other computer that I'll post if I remember.
I don't like them because they are oiled, so can introduce oil onto the AFM element and they don't clean very well. They also state they are for race only therefore call doubts about legality for road use.
Read the above I have posted. Will your non turbo GTS-4 be pulling more power than my GTR? Stick with the stock (but modified for extra air inlets) airbox and use an Apexi filter panel and protect your engine. Would you use really crap oil in the engine? Why introduce dust that will increase wear more than some oils?
Sure it doesn't look as cool, but if you wanted to be cool you'd have a GTR or RZ Supra or late model RX-7 :(
    • f**king around with the bro
    • Ludenham   44.2 tops day no issues
    • Then today, I went to visit a man with an r33 hat Peter and Road and Race sorted the alignment. As it is being set up for general track/hillclimbs etc it has a heap of caster (7o), less camber than I am used to (1o front and 2o rear, as the caster looks after that in turns without the braking downsides), 3mm front toe out and 0 toe rear. Will see how that goes and track tyre wear to see if it does need more camber, but adjsustment is also limited with nismo arms and adjustable bushes at only 1 end. It does have a bent inner tie rod on the driver's side front but as it came up within spec I'll just leave that as is. So, that is getting close to my chapter of this story....could of tidy ups then a shakedown in early October before it finds a new home.
    • So, it went to Unigroup for a run in and tune on Friday, everything went (generally) well. In terms of fixes, the engine was good and there were no leaks. It needed plugs (I hadn't checked them because the coil pack cover was on a new engine and I couldn't imagine they weren't new.....but turns out the temporary plugs to just keep it sealed up were in there.....new plugs gapped to 0.8 and it was fine from there. Also, there was a little preload on the clutch slave which caused some slip. I haven't had the box off so I don't know what the clutch looks like; my guess it is brand new and the pedal had not been adjusted....backed that off a bit and it held fine. Last thing will have Dose crying....the idle especially when cold is a bit difficult between the cams, forward plenum, atmo blow off valve and an 80s air management system. It is fine when hot but a little uneven when cold, will see if I can sort or at least improve that one cold morning. Other than that, tuning went fine. It made 245 but was pulled back to 227 which 2 opportunities to improve in future. 1. The factory CAS is not great and was jumping around at high RPM, so Mark took 2 degrees out up top (that is why it stops making power and lost 20kw). Very safe this way and the extra power is available but will require a more modern ECU and better cam (or even better crank) sensor 2. The 2871 in factory housings is very big for a low mount, and the internal wastegate is too small, so it was creeping from mid range all the way to redline....the duty cycle on the boost controller is turned down a little for safety. That is much harder to fix, it would need a large external gate and that would require a whole bunch of other changes, so it will go as it is for now. It feels nice and healthy and safe, so should be good for about a billion laps like this.
    • what sort of caliper are they? If they are a slider and you gave everything a good clean, you might need to regrease the pins. My guess though is they will come good after some abuse as suggested above
