Just a quick update to let you know who has paid a deposit. Just to confirm aswell. Make sure if you have left a deposit that your on this list! If i have missed you let me know, and if you have transfered a deposit recently dont stress as it takes a few days for it to show.
Cheers. Looks to be a good day, to anyone out there that wants to secure thier spot on for a run please contact me and ill send you the deposit details.
3. gtrGhosTDoGG11 paid *
4. DriftR_33 paid * 2 people
6. vange paid *
8. Nightcrawler paid *
11. Mr X paid *
14. mr_rbman paid * infull
16. Madaz paid *
19. chops paid *
23. Lee paid *
24. Crimmo paid *
25. Rolls paid *
28. Shannon paid *
Edited by gtrGhosTDoGG11
  • Replies 422
Posted Images
did u finaly recieve payment from shannon?
if so he isnt able to make it now due to going interstate weekend before was perfect for him ... not too worrie
but keep his payment as the rest of mine and lee's run and well sort out wot is owing on the day
Edited by Madaz
6. vange paid *
11. Mr X paid *
16. Madaz paid *
19. chops paid *
23. Lee paid *
24. Crimmo paid *
25. Rolls paid *
28. Shannon paid *
Can I deposit the lot at once into the account? main reason being that it cost's $5.00 for the transfer? (BankSA) Or prefer the $10.00 and $15.00
should cost nothing for direct deposits sux to be with BSA
I'd have to agree to that. I'll start looking around at various rates with other banks/businesses to get the most out of hard earned cash. By some chance Madaz are you removing some form of drive to allow for two wheels only? or is Shauns dyno awd? been there plenty of times but never took notice of this fact :s
Just wanted to know whether he minds having the whole $25.00 directly deposited, or still the $15.00 on the day and $10.00 deposit
gtrGhosTDoGG11: looks like shannons payment made it too a William Q Ho im guessing this is you ?
and description should either be a random number plate or Shannon Blackwell-King
he paid 25 dollars
Deposit paid ghosty, i could get few more chasers if want?
Erin
So...should we get some VL's in if we don't have enough numbers? were we looking for about 25 overall? (approx). If need be i can get one VL turbs to come.....
So.....do we need some more numbers? If so let me know and i'll grab a VL for you, nothing outrageous, just family relative. Also, money is in the account, so will see it no later that Wednesday :) (that's what the lady told me at the counter :O).
    • yeah first and reverse is where you will find clutch release issues (whether hydraulic or mechanical) because the difference in revs required is the highest there; particularly changing down from 2nd to 1st when still moving. To be clearer though, it is possible that the clutch release bearing is the wrong height. This is less likely than a hydraulic issue but it is not unheard of when you are mixing and matching
    • Quite right, if you make it to that pension you deserve every cent
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
