What kind of prices do Ideal Seat offer? Do they also stock Bride seats? I may buy a couple of f**ked ones and get them retrimmed, instead of buying brand new ones.
They only do Recaro, AFAIK. Start at around $1G. May not be cheap, but try getting a new genuine seat from Nissan and see what it costs you! The other beauty of Recaro (and other aftermarket) seats is that when you sell your car, you pull the seat and fit it to your next car. Then they become really inexpensive.
If you want your seats re-trimmed, there's a guy out in Ringwood, near the Autobarn store, does a good job. Can't recall his details right now.
Advan_01 - let your fingers do the walking.
https://www.sau.com.au/forums/topic/130032-recaro-seats/#findComment-2406702
Cheers thanks for that, I thought Ideal may have sold second hand Recaro's aswell. I'll definately keep that trimmer in mind, but it's a bit of a hike for me :lol:
I just need something that will keep my bum on the seat when I'm sliding :rolleyes:
https://www.sau.com.au/forums/topic/130032-recaro-seats/#findComment-2412605
I just need something that will keep my bum on the seat when I'm sliding :)
I don't thikn ideal do recaro anymore. I recently tried to source new recaro seats - and found it very dificult.
Best to get 2nd hand ones and retrim them. I had the retrim done through blackman and sons in morabbin. was well done.
https://www.sau.com.au/forums/topic/130032-recaro-seats/#findComment-2443264
I thought Ideal were the only supplier of genuine recaros in Australia?
98% sure they still do recaros. Wait, make that 100%, just read the article in this months HPI about the recaros in the R34 GTT.
www.idealseat.com.au
https://www.sau.com.au/forums/topic/130032-recaro-seats/#findComment-2445458
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
