Hi Guys,
As this section is taking off, why don't I offer to make some webspace to use with the cefirosaustralia.com and .net domains? If you guys choose somebody to be the admin dude, we can setup a portal and links to these forums etc. Let me know what you think, it'' be pretty straight forward.
Christian
https://www.sau.com.au/forums/topic/130189-cau-site/
  • 3 weeks later...
  • 3 weeks later...
things happen at 1/2 pace here on SAU... lol hang on while we sort out SAU first :)
Atm, its just looking like a front end for this section, so the forums itself will remain unmodified (same mods etc) but with a nicer front page when you go to www.cefirosaustralia.com
Since its only A31's, C32's and Y32's atm (unless you guys wanna include FWD maxima drivers with A32's and A33's) its quite limited on what we can put on the front page.
If you guys can brainstorm on what you'd like to see on a sorta front page (like the one you get when you go to SAU's front page) then we can get started on implementing it, and then getting a couple of you guys to update/maintain it regularly.
https://www.sau.com.au/forums/topic/130189-cau-site/#findComment-2517196
If it is only going to be a front end then I think this forum should be a bit more organised. I mean its a "lets put everything in the one section" forum atm.
Definetly needs to be an article sub-forum for all those 4 door specific item. And a member ride section, then perhaps the other crap that anyone wants to post.
My 2c :rofl:
https://www.sau.com.au/forums/topic/130189-cau-site/#findComment-2522963
exactly, what about c34 and 5, are there any in aus? :)
not yet.... they are sevs eligible, just need to find a workshop willing to crash test one and then start complyin em.
I'd go the gloria over the newer laurel tho.
tops idea will set up members rides section now.
https://www.sau.com.au/forums/topic/130189-cau-site/#findComment-2523050
  • 1 month later...
Yeah Im getting the same. This is just putting in www.cefirosaustralia.com
Result I get is below
VVVVVVVVVVVVVVVVVVVVVVVVVV
Forbidden
You don't have permission to access / on this server.
Apache/1.3.34 Server at www.skylinesaustralia.com Port 80
https://www.sau.com.au/forums/topic/130189-cau-site/#findComment-2620043
    • There's one for sale at Grand Auto Wreckers in Lonsdale (SA), for .... let's suggest the sum they're asking for will make you cry. You may have to embrace the idea of modifying the rear subframe to accept some other diff. You could probably find a way to wangle a shortnose into there, with a custom rear adapter and some sort of shenanigans to relocate the front mounts. This has probably already been done by others, so there might be some guidance available as to how easy/impossible it is, out there in the googles. But you possibly needn't restrict yourself to Nissan diffs if you're going to contemplate that. There are similarish Toyota diffs, possibly some Euro ones, possibly some Seppo ones.
    • The ball joint taper and arm taper have to match angle and diameter, but just doing the bushes is a much better option.....seems like the industry moved to "it is cheaper to replace the whole arm than take on the labour for changing this bushes", glad the aftermarket supports it
    • Gee she looks a bit rear heavy in that first pic! Sounds like a great project with the kids, but as I guess you know R series stuff is getting hard to find and pre that is pretty much impossible these days
    • Thanks GTSboy. I will inspect the valves actually, is this something I can do while they are still in the head? The block/bores don’t look bad to be honest hey, I can still see the cross hatches in the bores and they still measure 86.5mm. I’m not sure how to measure the installed ring gaps but I will do that and take it to someone who can.
    • I’ve had the same headache with my lowered car, scissor jack first then floor jack every time. Ended up grabbing an extra-low profile aluminum jack (about 70mm entry height) and it finally slides under the lip without drama.
