Hi Guys,
As this section is taking off, why don't I offer to make some webspace to use with the cefirosaustralia.com and .net domains? If you guys choose somebody to be the admin dude, we can setup a portal and links to these forums etc. Let me know what you think, it'' be pretty straight forward.
Christian
https://www.sau.com.au/forums/topic/130189-cau-site/
  • 3 weeks later...
  • 3 weeks later...
things happen at 1/2 pace here on SAU... lol hang on while we sort out SAU first :)
Atm, its just looking like a front end for this section, so the forums itself will remain unmodified (same mods etc) but with a nicer front page when you go to www.cefirosaustralia.com
Since its only A31's, C32's and Y32's atm (unless you guys wanna include FWD maxima drivers with A32's and A33's) its quite limited on what we can put on the front page.
If you guys can brainstorm on what you'd like to see on a sorta front page (like the one you get when you go to SAU's front page) then we can get started on implementing it, and then getting a couple of you guys to update/maintain it regularly.
https://www.sau.com.au/forums/topic/130189-cau-site/#findComment-2517196
If it is only going to be a front end then I think this forum should be a bit more organised. I mean its a "lets put everything in the one section" forum atm.
Definetly needs to be an article sub-forum for all those 4 door specific item. And a member ride section, then perhaps the other crap that anyone wants to post.
My 2c :rofl:
https://www.sau.com.au/forums/topic/130189-cau-site/#findComment-2522963
exactly, what about c34 and 5, are there any in aus? :)
not yet.... they are sevs eligible, just need to find a workshop willing to crash test one and then start complyin em.
I'd go the gloria over the newer laurel tho.
tops idea will set up members rides section now.
https://www.sau.com.au/forums/topic/130189-cau-site/#findComment-2523050
  • 1 month later...
Yeah Im getting the same. This is just putting in www.cefirosaustralia.com
Result I get is below
VVVVVVVVVVVVVVVVVVVVVVVVVV
Forbidden
You don't have permission to access / on this server.
Apache/1.3.34 Server at www.skylinesaustralia.com Port 80
https://www.sau.com.au/forums/topic/130189-cau-site/#findComment-2620043
    • I thought the same too, and more than happy for others to bring another source for what it is. Just throwing so me caution out there, as potentially an extra 30% current needed than expected.   Well worth more investigation, but right now, I'm going over my Cypher knowledge while Expendables 4 provides mundane noise in the background, ha ha!
    • If true then....wierd. That's a very high base fuel pressure for a shitty old early 2000s Nissan.
    • I may have my math slightly wrong, I'm not double checking that again, but the factory spec for fuel pressure is to set it with the engine IDLING (in vacuum). That spec is 51PSi while idling. So now add +10psi for atmospheric, and +7 for 7psi of boost, and we need 68psi of fuel pressure at full noise, and 51psi idling. That's according to the FSM I found last night for M35. So MINIMUM fuel pressure should be 51psi and it climbs from there.
    • Provided that what you see makes sense and is not "linear" between, say 1.9 and 2.1 volts and that's the whole range you get. You still need it to be doing one end of the 0-5v range at one end of travel, and the other end of the 0-5v range at WOT.
