  • Replies 46
Guest neoGT-25
your friend is exactly right... i live on government road in a townhouse complex :P
oh and to answer the "U say in there (from 174kw to 188kw) how did u get to 174kw.. i thought they were 145kw stock..?" question
i dont know... its just what the mag said... i dont drive yet so it would be had to cruise LOL
what school did you go to? i go to benowa and its a crap school :P
and also i wouldent know where to buy parts :P
hehe... byes :burnout:
https://www.sau.com.au/forums/topic/13035-my-car/page/2/#findComment-252013
haha madness man, i cant beilve u have a r34 and u are still in school u lucky basterd :P
yer i was at helensvale high man graduated in 99, yer that was a wicked school i had some good times there.
i lied im not really in biggara water i live about 2 mins from u u know whiting street...brown st im just down there :P
small world :P
are u licenced to drive it yet or not??
https://www.sau.com.au/forums/topic/13035-my-car/page/2/#findComment-252065
From what martin donnan said about his partners car
R33 door, auto RB25DE,
he recorded a 9% increase in power at the wheels with a 5zigen cat back exhaust.
impressive i think.
cam shafts, i have heard u can install some tomei cams, that dont requre ecu upgrades,and provide a 10% increase as well, get some adjustable cam gears to dial in as well.
An altenative to getting totally new cams is to reground the existing cams, though a side effect could be roughness in the idle, but i think i could live with that. :P
SAFC will make the most of you cars stock air/fuel ratio by maximising it.
i am desperatly saving for all of the above, and through a top bloke i could land my self a 5zigen R33 na cat back, wahoo
https://www.sau.com.au/forums/topic/13035-my-car/page/2/#findComment-252261
Just read that HPI article on NA tuning.
The results that they got, are CRAP.
after a cat back, 2 different extractors, 2 HKS camshafts with cam gears. And an apexi SAFC.
its only 88rwkw, up from about 72/74rwkw. Shit in my opinion.
i plan on getting all the mods mentioned, and from the research ive done, i will make alot more then 15rwkw
https://www.sau.com.au/forums/topic/13035-my-car/page/2/#findComment-255238
    • Why not? Since mines been built, I've used low boost maybe 5 times.
    • Yeah, so widen your search to any Nissan speedo first, then go wider if needed. I will say though, that there is a better than even chance that what I said first will likely come into play. They quite possibly won't come apart without damage. I tried to disassemble a stepper gauge that I wanted to repair. There was no way that needle was coming off the spindle, and I could not see how the spindle would come out of the mechanism behind. Assembled once, never to be disassembled, was my conclusion. Could be the same on the R34 cluster. Failing that - take the cluster to a workshop that specialises in automotive instrument work. There's usually at least one in every Australian city. They'll either be able to do it for you for small cost, or tell you it can't be done. It might be that "it can't be done" unless you follow some arcane procedure, including trickiness to glue it back together or something, that only experienced techs know.
    • Well, given that I, an engineer, almost never bring out the torque wrench to tighten up chassis bolts, despite fully knowing the theory, and instead rely on feel, which I happen to know is exactly how the majority of mechanics do things, should tell you the level of actual peril that exists from not achieving exactly 88 Nm of torque. How about if I just say then that 88Nm is at the lower end of the correct wheel nut torque range? Everyone knows how to tighten a wheel nut, right? And almost no-one ever brings out the torque wrench for that task
    • Don't be ridiculous. "2-3 ugga duggas or one Oof. You have to use Oof on tie rods because you can't get an ugga dugga on there." Is not helping the guy at all.
    • I have done a lot of research before posting here and on gtruk forum. couldn't find anything. I have my gauges all part except the needle itself. the needle has a extremely small hole in the center, but the shaft going to the needle is extremely small and appears to have nothing to index it either. doesn't seem strong enough to simple pry or pull without damaging something. Already tried the old spoon trick on a extra triple meter I have from a gtt, but no luck. the center cap comes off easily but the hole in the meter face plate aren't big enough to get over the needle itself. figured this would be my best place to find someone who might have actually removed theirs. wonder if there is some type of small pin press tool to push the pin in while pulling the needle base off.
