dabigbolf: sounds like u want the extra turbo power.. without the costs involved!
don't forget all the extra stresses on the engine.. clutch, fuel system, gearbox, pistons, rings, rods, head gasket, everything if you go too fullsik on power. Budget at least $3k for a mid-range turbo upgrade (around 230rwkw) which u can keep much of your standard stuff (but be prepared to fork out if they go)... If u want fullsik... budget at least $6-$8k+ on your upgrade and get around 300rwkw
for now i just cant wait to get my car on the road. i was just thinking of this cause i was bored.
interesting wat peoples view are though.
and WASTED. dont u think if everyone had Rb26's it would be a pretty boring world. sometimes you just gotta try something different.
when i want power i drive the car in the place where is produces more power. when i dont want power i drive in the low rpm's where is more gental and quiet. and if your wondering how to drive your car in the range where its producing the most power. pick the right gear. not really that complicated.
Hey dabigbolf seriously if u want big power u gonna get big lag, the smaller your exaust housing the lower your top end will be. Ball bearings get to the essential stage when we are talking big power figures to reduce any further lag problems...
It sounds your scared of a laggy car what i would suggest is when do u want your full boost to come on at what rpm then you can rule out certain turbos.
Saving for the Ball Bearing equivalent gives you a bigger HP turbo with the same amount of lag
I want Full boost to come around 3500 and i think i can acheive 350wrhp with that pretty easily
At current Im pulling 300rwhp at 1bar and getting full boost by 3000 puts the smile back on the dial but the compressor wheel that achieves me to reach that full boost so early surges a fair bit on slight throttle openings...
    • So either way it is gearbox out and look what is wrong?  I know about the input shaft bearing. Even before swap/new clutch the it sounded exactly like this: So is that inout shaft bearing or the other was installed backwards?  And can some please tell me the part number for that input shaft bearing? The gearbox is small box from R34 N/A and number is FS5W71C. Thank you
    • I am yet to see anyone ever regret a quaife or helical. ...other than drifting/skidpan duties. I kind of want to upgrade my factory helical with a Quaife (but really it's not ultimately that different, and is a MASSIVE UNDERTAKING), that's how good the hype is about them, that I want to try them 'just to see'
    • D2 and Ksport are essentially the same thing and basically just generic Taiwanese manufacture. Better than ChinaBay crap, but... not top shelf. Öhlins have got to be some of the best dampers around, so likely to be a good option. It's going to get to the point though where I suggest you buy from Oz. We have at least 2x excellent options here. If I were you though, I'd be talking to KW about doing something for the R33. There's bugger all difference between that and the 32. In GTR land, anyway.
    • KW only offers a set for the R32 GTR. Popular options are D2 racing, Ksport or Öhlins. I have a D2 Racing coilover set, though I don't know for sure which one.
    • Well, the good news is you have more than one very good option for new coilovers in and around your country. Worth the drive over to KW to talk about GTR stuff.
