*Fibreglass R32 GTR Rear Wing - $80
*Bridgestone Potenza Shocks (stock length, front and rear) suit R32 GTS-t - $150 for all 4
*Standard R32 GTS-t Front and Rear Swaybars - $10 each
*Standard 2 1/2" Cat - $10
*Standard R32 GTS-t Dump & Front Pipe - $20
*Standard R32 GTS-t Rims x 4 - $250/set - Tyres No Longer Available
*Standard R33 GTS-T/S14 Rims x 4 - $250/set - Tyres No Longer Available
*Standard R32 GTS-t Turbo - blown - would make good turbo for highflow - $80
*Standard R33 GTS-T Turbo - No Shaft Play, Appears to be GREAT condition, just makes a whining noise all the time (i.e. does it even when not on boost) - $200 - SOLD
*Standard R32 GTS-t Front Brake Rotors, good condition - $100
*Standard R32 GTS-t Intercooler - $40
Non Skyline Related Parts:
Autometer Water Temperature Gauge - Never used - $150
AE82 4AGE Inlet manifold - $50
AE86 diff housing (no centre) - $20
AE86 rear drum brakes - $Free with Diff Housing
Holden 202 Inlet manifold - $20
Holden 202 Varijet Carby - $10
Blown Amp - $Free
Woodgrain Steering Wheel - $50
These parts are just off the top of my head, i quite possibly have other stuff laying around as well, which i will add as i find it!
I am open to offers
parts are located in Brisbane
Please contact me either on my mobile - 0402 202 978
or via PM
or via E-mail (jwgeh @ tpg.com.au)
Many Thanks
Jason
https://www.sau.com.au/forums/topic/130407-assorted-skyline-parts-others/
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
    • What sold me on Trailer Park Boys is this scene: Great stuff, just stay clear from the new Netflix production.
