I am looking at buying an early 300ZX VG30t (2 cam engine) for our class 5 offroad car and am seeking info. Has anybody used one of these engines with reliability and success? What manual g/box and b/housing do they use? Where can I buy a Navara front entry inlet man.? Has anybody got a std computer and eng. loom? How much boost will std engine take with correct tune? Anybody built replacement turbo exhaust manifolds?
https://www.sau.com.au/forums/topic/130410-300zx-vg30t/
Check out http://z31.com/
These cars are fairly heavy and stock have the same output as VLT (150kW at the flywheel). Be warned that they are renowned for spontaneously bursting into flames.....heat buid-up in the 'V' of the engine causes fuel leaks and, well, instant BBQ. Nissan did a recall in the US to fix the problem, but never admitted to anything in Oz even tho many owners have experienced 'the problem'.
Gearbox in the stock Z31T is more-or-less the same as RB20DET type, but fortunately the gearbox in RWD Navara is as strong as the RB25DET type and will bolt up.
An option for upgrade is VG30DET from Cima....190kW stock, but might not be allowed for your class.
Suspension setup is largely the same as Datto 1600 and 280ZX (+ R30 Skyline, etc)....semi-trailing arms at the rear plus mac struts up front.
Edited by SteveL
https://www.sau.com.au/forums/topic/130410-300zx-vg30t/#findComment-2412982
I havnt been envolved in Off Road racing for a couple of years but if you want to enter class 5 in a full body car and you are changing the engine, use a lexus 4ltr v8 :D
Reliability of these engines regardles of abuse is amazing.
As far as im aware the origional body shape must remain but everything else as long as they remain rwd can be changed.
I used to follow this car around being attatched somewhat to the family.
Class 1 with a Stock Toyota 3SGTE
Its awesome fun
What car do you plan on using?
https://www.sau.com.au/forums/topic/130410-300zx-vg30t/#findComment-2413389
We bought a 120y 2 door that was built for class 5, years ago. It has a recessed fire wall. It has a 180b diff assembly in it. We are going to get it going with a hotty L18 and 5 speed but I am liking the idea of a VG30t.
Edited by skidkid
https://www.sau.com.au/forums/topic/130410-300zx-vg30t/#findComment-2418431
Anybody know of any vg30t powered buggies or offroad cars?
I have never seen nor heard of one being used.
You would probably be the first.
But the weight of this engine in a 120Y would be bad for pretty much all soft tracks and i wouldnt think it would do you any favours.
It would be definately more suited to another car/buggy
https://www.sau.com.au/forums/topic/130410-300zx-vg30t/#findComment-2423500
Slide, Are you able to give any tips on budget building some long travel (8"- 12") Macpherson strut front suspension. The car has Bluebird struts in it at the moment. Or do we need to fit some a-arm / vw front sus.? Can you provide any tips/ measurments of lenghts, angles, shock mount position when building a-arm? With the 180b rear what sort of angle can you run on the shafts? With the car sitting still what sort of cambers do we want? Cheers, Jason.
https://www.sau.com.au/forums/topic/130410-300zx-vg30t/#findComment-2426810
I dont really have any technical knowledge of your particular class but if you are going to be envolved with SORRA (Sydney Off Road Racing Association) then post up in the forums or get out to an event but places like Gondawindi and such require some good suspension setups to cope with the likes of this sort of air time.
Even with these i have seen strut towers come clean out of the bonnet so go nuts with the support welding. :O
Start here
http://www.offroadracing.com.au/
http://www.offroadracing.com.au/links.htm
If you currently attend a few events just go and speak with some Class 5 people.
There used to be two guys from Dondinalong i think with 2 Datsuns but im sure both of them have been retired now for the tube Buggy setup.
Because you dont want this to happen.
https://www.sau.com.au/forums/topic/130410-300zx-vg30t/#findComment-2430445
    • Ha ha ha, that's fair mate! We have the crackhead dogs now. Mainly because the missus wants the crazy dogs while she still has the energy and capacity to be able to keep up with them! Ha ha our current two are both Working GSD, there brothers and sisters (from the same litters) are in Police, Corrective Services, and I believe one did end up in defence force too. They're wild and fun, yet right now, both curled up asleep on the lounge room floor while we watch some TV. Mal is very likely the next dog (unless I get my couch potato guardian dog 😛 )   What are your Kitties names? Are you planning some house work, like those high kitty shelves, built in scratching post, and some cat passages from one room to another room?
    • Maine Coone, did look at but to big and fluffy As for performance dogs, we had Mals at work, performance dogs are fun to watch, but, way to much work for this old rooster
    • Yep, it was only an option on the Q50 Hybrid.  Same in Japan as far as I know. And doesn't use a centre diff like the Suby's do, so not the same as the WRX.  But it also isn't a reactive AWD like other Nissan AWD vehicles are, eg. Murano/Xtrail/etc.
    • You should have got a Maine Coone then. Only thing is they're big. But so cool, and just like a dog. Or, just get yourself a high performance dog. That'll teach you for wanting Parkour indoors 😛
