hey all,
just noticed a huge puddle of dirty rusted water undearneath my car where it was parked and after further inspection noticed a leak from underneath, its dripping like a rusted liquid (its not oil), possibly coming from the water pump?
anyone have any ideas on what it could be?
any help appreciated, thanks
https://www.sau.com.au/forums/topic/130475-leak-in-my-r33/
is it coming from the area directly behind your radiator fan?
look under that area and there is a small hole in the bottom of the water pumps drive/bearing area .. if it is coming from there.. your water pump is cactus and needs replacing
https://www.sau.com.au/forums/topic/130475-leak-in-my-r33/#findComment-2415296
damn that water pump. Had to change mine, took a day for them to change it - and they did the timing belt and all that in the process as well...
lol tell me about it, thats exactly wat they are doing to mine, took it down to re customs today :huh:
https://www.sau.com.au/forums/topic/130475-leak-in-my-r33/#findComment-2416038
    • I like their veal scallopini.
    • Definitely a hearty eater when we go out, I consider these meals my cheat day as I've been watching my calories in and calories out pretty hard since my little fun size stroke, I've gone from a fat boy of 89 Kg, I'm only 165cm tall/short, down to a almost semi lean 73 Kg over the last few years, I'm currently around 17% body fat which my doctor is very happy with, but, my goal is to slowly get down to and maintain 15%,so yeah, I want all of the protein, carbs, fats and sugars when I go out for a binge
    • There was a great one on Victoria Rd in Gladesville too back in the day. I can only assume GTSBoy is thinking of the mill up on the wollondilly, no restaurant there any more but they have restored the original steam engine on site and run it every few months, have an annual steampunk festival etc @The Bogan, you came to the wrong town for restaurants. we have a few reasonable asian and indian options but the Paragon is as good as it gets otherwise. That brewery is apparently just opened, been meaning to give it a go some time. The Highlands have plenty of fancy options but I suspect you are more a hearty eater than fancy eater
    • Thanks for coming back to post the update, maybe it will help out the next person!
    • Going by the intake & injectors I'd be guessing it's a DE, check the head casting number, should be 5L8 on a DET, 5L7 I think is the DE number.
