Here is mine, nice and clean again (rain makes it look a bit dirty)
Skirts are fixed and back on - finally - only took me 2 years to get around to doing.
Any idea what side skirts I have? They are different to the stock ones I have seen as these wrap around underneath where the door closes.
gtr style rear pods right? i think i might get some as an alternative to changing the whole rear bar
I lvoe that gtr GODZLR. Very nice Matty P. Got any engine bay shots?
Took this photo a few months back in my garage, and depetched it.
Not a fan of the polish cover as it gets dirty pretty easy, so it will get airbrushed eventually down the track in purple with some sort of design on it (inspired by TOP RPM engine cover).
Will replace those ugly green hoses too & got a Trust oil filter relocation kit for it, yet to be installed though...plus some other goodies lined up to finish it off for now.
Edited by MattyP
re: your sideskirts... they're just replica GTR ones.... they're simple, but i think they look tough... i got the same.
    • Is it alright to top up with just another green coolant?
    • thanks GTSboy. My confusion at the moment is i am trying to locate the ignition, ECU battery power and the ECU negative The closest thing i can find is the for the S15 on Page 8 of the Wiring Specialties web page https://drive.google.com/file/d/0B9F33_M_GgENQnZ6STMxVmVNd1E/view?resourcekey=0-eZ4nNRwRoqa1qvKlWWHm8A I cannot find the same diagram for the R33 RB25DET Series 2 dash plug pin out.... Do you know what the Pins? or know where i can find the same pinout diagram for the RB dash plug? Thanks for the advice on the box... i like a 6 speed so might be on the lookout or the box now.. a topic of discussion for another post...
    • Will have a look at that. I cant see any leaks
    • Put another overflow bottle (ie, a 1.25 coke bottle or similar) under the overflow hose and see if it is being pushed out there or if it is disappearing into the engine.
    • Staring on a stand is no issue. You just have to wire everything up, give it fuel and cross your fingers that the stand is robust enough. Arranging the inlet plumbing is often the hardest part, without any surrounding structure to hand some of it from. No need for coolant if you only want to run it for <1 minute. As to the gearbox - I think the little Aisin box is a bit stronger than the other small Nissan boxes that went behind SRs, but I wouldn't be too keen to test its limits with the torque of a boosted 25. I don't know if you can retain the box and the tailshaft. The box won't connect to the RB without an adapter of some sort, which is either a plate that will push the engine forward (which is not good for fitting it into the bay's available space) or push the box back, which messes with the box position and tailshaft length - OR - cut and shut work on the bellhousing, which is a long way from "least modification". I'd be buying a new 370Z 6 speed or similar, doing what has to be done to that to make it fit RB (ie, cut and shut bellhousing) and the requisite tailshaft custom/mods.
