I'm finding when i click on a link to view a topic that the page is loading, then reloading, then reloading again, so that if i hit the back button i have to go back through up to 20 copies of the same page to get back to the index.
It seems to be a consistant number too, if i go from the main page to the forced induction subsection it will load the page 3 times, and topics generally 7 or 8 times.
Viewing topics in suspension braking and tyres it's up about 20.
If i right click the link and open the topic from there it will only open once, so i hit the back button once and i'm back in the menu
https://www.sau.com.au/forums/topic/130494-pages-loading-multiple-times/
Not sure if I have same problem... I Haven't noticed the pages reloading, but The back button isn't working on Sau forums :O
ETA: Ok Forum home page just loaded 3 times. It doesn't do it visually, but in the 'back' button drop down arrow its there 3 times... and if I hit back 3 times I will go back, but I can't go forward... Sounds confusing... :O
its all good but the bit down the bottom
2 User(s) are browsing this forum (0 Guests and 0 Anonymous Users)
2 Members: StageaGirl, Shell
that tells you who is browsing is and « Next Oldest · Ideas/Feedback & Bugs · Next Newest » is in huge font..
    • I don't. I mean, mine's not a GTR, but it is a 32 with a lot of GTR stuff on it. But regardless, I typically buy from local suppliers. Getting stuff from Japan is seldom worth the pain. Buying from RHDJapan usually ends up in the final total of your basket being about double what you thought it would be, after all the bullshit fees and such are added on.
    • The hydrocarbon component of E10 can be shittier, and is in fact, shittier, than that used in normal 91RON fuel. That's because the octane boost provided by the ethanol allows them to use stuff that doesn't make the grade without the help. The 1c/L saving typically available on E10 is going to be massively overridden by the increased consumption caused by the ethanol and the crappier HC (ie the HCs will be less dense, meaning that there will definitely be less energy per unit volume than for more dense HCs). That is one of the reasons why P98 will return better fuel consumption than 91 does, even with the ignition timing completely fixed. There is more energy per unit volume because the HCs used in 98 are higher density than in the lawnmower fuel.
    • No, I'd suggest that that is the checklist for pneumatic/hydraulic adjustable systems. I would say, based on my years of reading and complying with Australian Standards and similar regulations, that the narrow interpretation of Clause 3.2 b would be the preferred/expected/intended one, by the author, and those using the standard. Wishful thinking need not apply.
    • Yes they do. For some maybe. But for those used the most by abusers, ie Skylines, the numbers are known. The stock eyebrow height for R32/3 Skylines is about 365/375mm or thereabouts. The minimum such heights are recorded in adjacent columns in the database.
    • Hmmm, interesting. Makes me wonder whether there is bias as well. It's the cheapest fuel, so it is used for all kinds of ill-maintained shitboxes which are bound to have issues regardless. Nicer cars tend to require higher octane rated fuel and can't use it anyway. FWIW, the official NSW E10 facts page is decent.
