  • Replies 245
Posted Images
nizmokid: On the street you'd probably won't notice much difference.
Swapping disc alone won't immediately give you better braking performance,
there's a lot other factors you need to consider: pads, fluids, is your std
rubber lines getting old, etc. For example even if you have brembos but your
fluid is sh1t and pads are worn, it's not gonna work well.
What it does with the slots are you can expect getting a lot more consistent
performance after going hard for 4-5 laps (on the racetrack - not street, please)
which is due to better cooling and reduce of buildup dirt/gas/water between the pad
and rotor surface. But even if you don't take it to the track, on the street you may
have a little bit better performance in stopping if your other brake components
are in good nick condition. Plus it looks better, and good value for money if you
need to replace your worn out rotors
r33fourdoor: there's R31 GTS in the xls list. So I'll put your mate in.
$302.50 without 20-25% discount. See 1st post in this thread. I haven't got exact $ on freight, but they're willing to organise to distribute to the closest RDA branch in your major city so even if you need it delivered, a local metro delivery in your city wouldn't cost much.
Yeah why not put me down for a pair of front slotted for r33 gtst series 1, providing they will fit with standard wheels on there
hey im after a full set front and rear for a R33 GTR V-SPEC ( brembo's ),
324mm front and 300mm rear can tou posta cost or a pm please im very keen just in process now of buying
cheers mike
trick: i've put you in. will let you know final price after discounted, if you're not happy with it u can pull out of the group buy, no worries.
r33skyliner & operationsideways, list updated on 1st post
dd4321, I'll start with the ordering next week, so as soon as I've sorted out the price and payment, then perhaps it's possible to get it in the next 1 or 2 weeks.
    • Thank you, 100% the intent. New coils were due and the 17" sixers look/feel loads better than the stock wheels. The aero options are so spot on.   Thanks for the warm welcome, all!
    • 98 r34 gtt Been rocking my latest setup and car running like never before. Have put a good 200 miles on it since all the latest changes and additions. everything is dialed in and have been driving it a bunch.   However, all a sudden last weekend as soon as I pushed throttle passed 4k and the engine stumbles, (slow or fast acceleration) hesitates and doesn’t go above 4100 or so, like a misfire. Everything else seems fine. I had a “good” set of coil packs that I removed from car when I first got it when I changed them over to new coils. I swapped out current ones for those, but no change. I also changed the plugs, no change. Seems to rev over 4 when out of gear with no load just fine no “misfire”, but as soon as its in gear with a load of any kind, it “misfires” as soon as rpm drop back below 4 k it runs perfectly, smooth, starts, restarts and drives fine as long as I keep it below 4 k while in gear. All readings look fine, no CEL   Any idea as to what could all a sudden cause an issue when pushing rpms passed 4 k?
    • When you say your cams are 272/262 is that 272in and 262ex?
    • We're arguing semantics. I am saying 45 accel and a 55 deccel ramp are "2 ways". Even a 45 degree ramp and an 89 degree ramp is "2 ways", because it is literally... two ways. The cusco 55/30 ramp is a 2 way. It's two ways. I get it though - in normal nomenclature a "2 way" would be 45/45 or 55/55 or 60/60 i.e the same locking in both directions. And something like 45/65 would be considered "1.5 way". I would then say if we're getting into the nitty gritty then every locking diff is a "2 way" diff and we should not speak in 1.5, or 2 ways but ramp angles instead. Which ofc if one of those ramp angles is 90deg, that side is not doing any locking. :p So Nismo don't obviously sell 3 things. The fact of the matter that they only sell two items really goes to show that there's a 2 way and a "1,5 way" which is really a 1 way. I believe the actual lockup for the 'adjustability' of the GT pro is really just setting preload for when the ramps actually start locking up. It's not changing how much 'wayness' there is. It is (somehow) horribly explained. People just buy whatever diff and go "locks up good bruh" and that's what ends up on socials forever.
