ECUTalk Consult LCD Displays
Edit: 28/1 - Donated $50 to SAU
Edit: See video (~7.5mb) of it in action, and a writeup of whats happening in the video at different points.
As anyone who is keeping up with the consult lcd display thread ive had going here on sau and on pga for the last 8 months, will know im getting very close to finialising the device. Ive decided to start this thread now to better organise everything.
As it uses the consult port, you will need a car that:
a) supports consult (ie, you have the plug near ur fuse box), and
b) still retains the stock ECU (piggybacks and remaps generally fine), and
c) doesnt have messed up wiring to consult port (shouldnt, unless you have an engine transplant or some other reason the wiring may be been fubared - eg it was on my old rb25 silvia).
For skylines, this is the R32's (10/89 + i think), R33, R34 (all variants except CA18 engined skylines, if anyone actually wasted money importing one!)
This follows on from previous successful group buys ive done for DIY Consult Interfaces and the same thing but assembled.
Display Hardware:
Edit: On the cable there is a "black blob". Inside this, there is a flattish voltage regulator (drops 12-14v to 9V), and a 0.5A fuse (the more rounded bit). A spare fuse is included with the device (this isnt a loose component).
The device is 188mm wide, 37mm high (39mm with buttons) and 28mm deep, and weighs around 300g (depending on cable length). It is quite compact is takes up only slightly more than the LCD display itself does (which is 182w x 33.5h x 14d without connector).
It has a right side and a rear holes for possible cable exits. It has two cables from the device - one for the integrated consult interface (serial connector, plug into serial port on laptop) and one to the consult port (genuine consult connector).
The device itself has 3 buttons (red, white and grey/black) on the top of the device, going left to right from the left of the device. The buttons are used to navigate through menus and the different features of the device. The red, or leftmost button, is the enter/select button, which either initiates the menu (from the main display screen) or selects the currently selected item from any other menus/screens. The white (left) and grey/black (right) buttons control the position of the cursor mainly in any of the menus. It should be pretty easy to work it out when you use it.
About 10mm to the right of the buttons is a switch (only slightly above the surface, and might not be very visible in the picture). This switch selects between lcd display (LEFT) and consult interface (RIGHT).
The screen is a standard 40x2 backlit screen, wide temperate (-20 to +70 operating, -30 to +80 storage), and has the best viewing angles ive yet to see in a 40x2 screen (50 above, 60 below, and 40 left or right), let alone a wide temp version which is needed for keeping in hot cars (pun intended).
Display Features:
The display has sensor display, fault codes, time trials (0-60, 0-100, 0-160, 400m), options setup, peak values, integrated serial consult interface, and a device info screen. Rather than try to describe them, its probably easier to show what the screen will show (more or less). When the display turns on (when ign is on), it first goes to the sensor values screen. from there, hitting enter (red) will bring up the main menu, from which everytihng is accessible.
On all menus: 'X' denotes current cursor position. left/right to move, and enter (red) to select the current item. most of the info below is zeroed out or whatever, when its running youll see actual values of course. by default ive just stuck the X in the first option.
main menu:
| [X]Display [ ]Error Codes [ ]Time Trials |
| [ ]Options [ ]Peak Values [ ]Device Info |
display: will look different with different options (eg tps %, etc)
| 000kph 0000rpm 00.0v EC:xxx INJ:00% 00oB |
| AAC:00 O2:.00v 000oC AFM:0.00V TPS:0.00V |
error codes: an error code has: xx - the error code, "description" name of error (or close enough to it) and (xx) = number of times the car has started since the error has occured
| [X]Exit [ ]Clear	 xx description (xx) |
|  13 Coolant Sens( 1) 15 Oxygen Sensr(12) |
time trials: havent completed the 400m one - may remove that (very difficult to do, but will attempt it)
| [X]Exit [ ]0-60 [ ]0-100 [ ]0-160 [ ]400 |
| Last Time: 000.000s  Best Time: 000.000s |
individual time trial: distance may be removed if i cant get it to work. when u start time trial, the clear/exit options have a [-], meaning they cant be accessed (till you stop the time trial)
| [X]Exit [ ]Start [ ]Clear  Best:xxx.xxxs |
| Speed:000kph Distance:xxxm Time:xxx.xxxs |
options: pretty self explanatory - press enter when ur on option to toggle between alternatives
| [X]Exit  Move to option, enter to switch |
| [ ]Speed:KM->Mi [ ]Temp:C->F [ ]TPS:V->% |
peak values: reset, well, resets them!
| [x]Exit [ ]Reset  000kph 0000rpm EC:xxx  |
| INJ:000% 00oB 000oC AFM:0.00V  TPS:0.00V |
device info: bit of random info on the device. press enter (or any button, forget) to go back to menu
| ECUTalk LCD Display Version 1.0 11/08/06 |
| Copyright Your Mother, www.ecutalk.com |
The display is upgradable for most minor changes made (if they are made after you purchase one), so dont be concerned about missing out on anything.
Group Buy Scheduling:
Once testing is finalised, ill be making the devices for everyone else as quick as I can, but i imagine maybe 5-10 per week.
Total run will be around 48 displays. Some may be sold on PGA or on a case by case basis to those overseas. So total amount available here depends upon demand. If demand is high ill try set up another run later on.
Price and Payment:
$200 pickup or +postage. Its likely price will rise after this initial group buy if i make any more (as im just breaking even assuming i sell all displays).
Comes with a 18cm strip of velcro for mounting. (the glue on the velcro isnt that good, doesnt like direct sunlight...up to you whether you use it to mount or something else).
Payments will only be made when ive confirmed that a device is available - i wont require or accept any up front payments to keep things easier to manage. Selling my RB25 Silvia gave me $10k which i hadnt had any reason to use, so now ive used almost all of that up, i need to get it back :rofl:
$2 per unit sold will be donated to SAU (will be donated at the end of selling this first batch). Wish i could donate more, but any more and ill risk losing money :rofl:
Pickup is from Blacktown, Western Sydney, or possibly near Wynyard in Sydney (I work there a couple days/week).
Postage is via: Express Post($7) or Registered Post ($10). Registered may take longer to send out if i have to do it over the counter, and its naturally slower to arrive than express, but it does have insurance for $200 (though ive never had an express post item not turn up).
Payment is via bank transfer (St George, arrives day after at earliest), or Paypal (instant, but has an additional fee of $6 unfortunately). Paypal is only an advantage when bank transfer is inconvenient, or you want the device ASAP (eg its 8pm and bank transfer wont be processed till the next day, and arrive in my account the day after that). You dont need a paypal account necessarily to use paypal, just a credit card.
OK i want one, what do I do now?:
I want to structure the group buy such that those who expressed interest first in the relevant threads here on sau and on pga will get first preference.
If you are not on the list, simply post in this thread that you're interested. I will, as i make the devices, ask the people in the list via PM in turn if they still want one, and if so, request payment. If they can provide payment within a reasonable time, they can purchase it then and pickup/get it posted. Otherwise, they'll either be removed from the list or put to the end of it, depending on whether theyre no longer interested, or just cant pay right now.
Things ill ask for when I've got displays ready and you're next on list:
Required:
1) Your full name
2) Your address and phone number
3) Email address (if u have one...for updates in future)
4) Your payment method (bank transfer, paypal (+$6 fee), or pickup)
5) Post method - either:
express($7, preferred) or
registered($10, can't be sent out as quickly as express as requires going into post office), or
pickup - if you want to pick up, then your availability (so i can tell you when is good for me).
6) Do you want the cable exiting the rear (back right corner) or the right side? (think about where you want to mount it)
7) What car(s) you want to use it on (+confirm uve read second paragraph of first post about what car's itll work on) - let me know if u dont want car info public on orderstatus page
Optional (defaults = quicker to make/send):
8) Cable lengths: standard is 150cm for both serial and consult cables. You can specify your own lengths, but i wont add the cables to your display till payment is received (so you wont get it as quickly). Cable lengths dont have to be the same.
9) If you want a non-standard serial number (standard: SN:00xx, eg SN:0025 for 25th display), give me an up to 7 character (eg "1_24 dg") serial number. This is for device info part of display - doesnt change functionality at all
10) Whether you have a laptop without serial port and would like a serial/usb converter (see here), +$20
Peter
Edited by NewKleer
https://www.sau.com.au/forums/topic/130985-ecutalk-consult-lcd-displays/
  • Replies 279
Posted Images
Order Status
Current order status for those who've been contacted by me can be seen here:
http://www.ecutalk.com/consultlcd/orderstatus.php
Interest List
If you're interested but not on the list, reply to this thread. If you're no longer interested, just send me a pm and ill take you off. If you thought you already indicated you're interested in the old thread, pm me the link to your post and ill stick you in the appropriate position on the list (dont edit it the post, as ill take last edit date for position on list). Also let me know if you dont want your username to be public.
When devices are available, ill PM people in order of the list and ask if theyre still interested/payment details etc.
Sold
kjb_r33
PranK
Haysey
msnismo
TurboX
bilbo117
MANWHOR3
MsG_ChRiS
Interloper
insu
enilyks33r
Rudager
Space Ninja
muck
AnFz
RAZOR32
frother
phunky_monkey
CeJay
D_I_F
linkems
battery
Later
toy86
WogsRus
CATKICKER
Acolyte
46n2
KamikazeR33
mr moo
hazerb30
govich
Edited by NewKleer
I'll definitely grab one if all works well! I'm already on the list but thought i'd restate my interest!
I'll have to find out about making the K-type sensors into a sensor for the oil temp as well!
So many things, so little time!
cool, if u have 3 cars i could probably come over there to test it out (if u want to give it a go on all 3) if that sounds ok.
No problem, let me know whens a good time and we'll organise something
what month? does it have a consult port (easier way to confirm), if so should work. O2/AFM readings will only be for left side (hopefully sometime down the track when i do second lot of improvements, ill be able to add support for some option to read the right side o2/afm - but if ur car is going fine, the values will be close to the same).
hmm its an early one. i dont remember seeing a port when i had a look at the ecu a few months ago. is the consult port supposed to be next to the loom connection? or does anyone have a pic of the consult port?
hey mate im down for one, for a r32 with s2 rb25det. Has port near fuses.
cheers
Bret
ive been looking on the ecu for the port. no wonder i cant find it. :sorcerer:
What fuses - near the battery or under the dash?
Edited by SLIPPERY
    • The 296mm rotors are the R33 turbo brakes. The 310mm rotors are the R34 turbo brakes. The calipers are nearly the same, but not. They're the same caliper but the R34 caliper has longer legs so that it sits out far enough to go over the rotor. The pads are the same for both. When you say, "I bough tsome EBC"....did you just mean pads? Or rotors? 310mm rotors fit under 17" wheels. There may be some wheels without enough clearance though. I can't fit my fingers between the barrel of my wheel and the "corners" of my R34 calipers, but there is plenty of room behind the spokes. This is on Enkei RPF1. You can fit 324mm rotors inside a 17" wheel, but I'd be willing to bet that it would be close to impossible with the Nissan/Sumitomo caliper (using an adapter, of course), because the Sumitomo caliper is fatter than the Brembo caliper that is supposed to go on the 324mm rotors.
    • Hi. Can someone tell me what brakes(and mainly WHERE) can i buy brakes on R34 GTT? I bought some EBC which SHOULD go on my car(i have GT but it has GTT brakes) but it does not fit, Brakes are "too" small(296mm) Are 310mm be good or? I have 17 inch wheel so no "big boys" but for me driving i just need one that fits and i can get here in EU/Czech.
    • Since winter isn't that harsh anymore in Poland, i will definetely drive it 365 days a year 😉. But if the snow hits i will try it for sure and let U know. Only swap i am planning to do is of course R34 GTR front 😍.
    • Hey. Very valuable information about pitwork, I will pay attention when buying any consumable parts 🙏 As for the carpets - I got a handful of information from nengun, from which it appears that indeed the carpets for the driver's side are OEM. They are not able to show me any pictures due to the long chain of different sales entities but after I place the order, as soon as the goods arrive at the nengun warehouse from which they will send the shipment to me they can send me photos and if my purchase differs from OEM I can immediately return it / cancel the purchase. I think I will give it a try 😉. Of course i'll let you know what's what as soon as i get them P.s. I know the topic is not relevant to the thread, but both nengun and amayama have these SICK 😍 trunk room lamps available. Do you know anyone who ordered them? I need to have one in my car
    • I've managed to find this: Nissan_Stagea_AutechVersion260RS (1).pdf
