18 x 9 265 x 35 x18 yokohama 75% tread
18 x 8 245 x 40 x 18 " " 75% tread worn on insides
$2500
they are a gunmetalic bronze colour and not damaged in any way
the white spots you can see is powder that i have since wiped off
https://www.sau.com.au/forums/topic/1310-18-wedsport-wheels/
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
