  • Replies 46
mac33r, go down the pacific highway towards north sydney. turn right @ the miller st lights. turn left @ the 2nd set of lights. turn right @ the next roundabout. turn left @ the next roundabout and its just on ur left as u go under the harbour bridge
Another great dinner guys, thanks to all who showed up. Those highway patrol cops deserved some recognition - top blokes, especially knowledgable on their GTR's and of course their ownage of Tosh (Twice) was priceless.
I started to PM everyone the link, but now I can't be bothered. :)
Anyways, if anyone didn't realise, there are a couple of galleries on my webspace:
http://members.optushome.com.au/dal2
Nick, let Johno know there's some pics of his car there (if you haven't already).
Cheers,
Tex
Cheers. We'll have to scope some more areas to take photos, maybe get some sunset beachside ones (as I was talking to Tosh about earlier today).
Maybe an industrial area at twilight? Somewhere with stairs so shots can be taken from above would be hella sweet...
Anyway, if you've got any ideas let me know. :)
Tex
    • roller coaster of a ride. Alarm system was removed & main harness was repaired where possible. still no fix just random successful starts. moved on to the replacing the ignition switch and relay. well all this troubleshooting & repair has been going on, the car is at a paint and body shop being pushed around. Ive been going down there on odd days after work to get it sorted.
    • 5th November if you want to come out for a spin wakfield
    • PROBLEM WAS BROKEN COOLANT SENSOR!!! Replaced with a new one and its running mint.
    • I think he was only proposing to use the wire, not the sender. Simply because it runs from the right place to the right place. Personally, I wouldn't hack up the factory wiring like that. I'd just lay in the Defi loom.
    • From memory it wasn't too hard to simply see which wire ran where when you plug that in. Unfortunately also from memory the OEM sender does not use the same configuration 99.9% of gauges run. So in other words if you connect the signal wire that was running to the OEM gauge to your DEFI gauge you might find your oil reads at 200C or some other incorrect value. I remember having the same line of thought and then running new wires/senders to match the gauges I have. The pinout is available in the R34 workshop manual.
