fcruz3r Posted August 21, 2006 Share Posted August 21, 2006 Just interested in what size rims you have on your stagea ..ie diameter, width, offset. Im just wondering if its possible to fit deep dished rims on the stagea. Currently Im running on a set of 17 * 8 inch work vs-xx with 235/45/r17 on both front and rear. Im not sure what the actual offset is though...but I can turn from lock to lock without any rub and the rears fit without me having to shave the guards. somehow I get this feeling im growing out of the rims and looking to go 18's Link to comment https://www.sau.com.au/forums/topic/131169-rims-sizes-and-offsets/ Share on other sites More sharing options...
Sydneykid Posted August 21, 2006 Share Posted August 21, 2006 R33GTR rims on mine 17 X 9 X 30 mm with 245/40/17 tyres. Clear OK at 355 mm fornt and 345 mm rear. Even with a big load, race car on the back + spares inside. They need around 1.25 degrees negative camber at the rear though, which is around 0.5 degree more than I would prefer. Front is OK at 1.0 degrees negatice camber and 5 degrees caster. cheers Link to comment https://www.sau.com.au/forums/topic/131169-rims-sizes-and-offsets/#findComment-2426346 Share on other sites More sharing options...
3intheBack Posted August 21, 2006 Share Posted August 21, 2006 type in 'got dish" in the 'search entire post' and you'll find plenty of previous discussion on this topic. Link to comment https://www.sau.com.au/forums/topic/131169-rims-sizes-and-offsets/#findComment-2426422 Share on other sites More sharing options...
qikstagea Posted August 21, 2006 Share Posted August 21, 2006 this has been covered soooo many times.... start searching threads people!!! Link to comment https://www.sau.com.au/forums/topic/131169-rims-sizes-and-offsets/#findComment-2426498 Share on other sites More sharing options...
darrinspencer Posted August 21, 2006 Share Posted August 21, 2006 I have just fitted R34 GTR wheels to mine which are 18x9 30+ offset 245/40/18's Just like Sydneykid's car they are very border line on the rear to the outside of car The fronts fit in fine. I would suggest if you still wanted to run 9 inch rear's to get a offset on +35 to 38 for the rear It would look much better I also have some Volk GTC's in 18x8 30+ which suit for sale Link to comment https://www.sau.com.au/forums/topic/131169-rims-sizes-and-offsets/#findComment-2426626 Share on other sites More sharing options...
EGA41T Posted August 21, 2006 Share Posted August 21, 2006 ive got 18 by 9 inch work rims with +35 offset Link to comment https://www.sau.com.au/forums/topic/131169-rims-sizes-and-offsets/#findComment-2426704 Share on other sites More sharing options...
Ska Posted August 21, 2006 Share Posted August 21, 2006 Yeah search for got dish, lots of pics of my 18"ers, atm they have 235/40R18 on it and they have to have way -ve camber on the rear to fit them when you lower it till you have about 1mm ground clearance Link to comment https://www.sau.com.au/forums/topic/131169-rims-sizes-and-offsets/#findComment-2426768 Share on other sites More sharing options...
IMPORTD Posted August 21, 2006 Share Posted August 21, 2006 I got 18's with 245's... no idea how wide. They are toyo's Link to comment https://www.sau.com.au/forums/topic/131169-rims-sizes-and-offsets/#findComment-2427122 Share on other sites More sharing options...
fcruz3r Posted August 21, 2006 Author Share Posted August 21, 2006 yea ... i think i'll play it safe and get 235 18's ..anything more and its touch and miss Link to comment https://www.sau.com.au/forums/topic/131169-rims-sizes-and-offsets/#findComment-2427321 Share on other sites More sharing options...
