Hi everyone (most notably SK).
Just wondering if anyone has done a 4 corner balance (as in weighed car on 4 scales) after installing height adjustable dampers?
And if so what were the results?
I ask this as I am about to install a set of Tein Flex Dampers and had read somewhere that to be totally accurate and for drivability this is the method best employed.
cheers
Muz
https://www.sau.com.au/forums/topic/131192-balancing-car/
yes i've done it. i dont quite know what you mean by 'what were the results'... well the result was the cross weights were set correctly, and the suspension heights set accordingly. if you want the corner weights set then just take it to a suspension place and have them set it up for you. easy. :wave:
https://www.sau.com.au/forums/topic/131192-balancing-car/#findComment-2428056
yes i've done it. i dont quite know what you mean by 'what were the results'... well the result was the cross weights were set correctly, and the suspension heights set accordingly. if you want the corner weights set then just take it to a suspension place and have them set it up for you. easy. :O
Sorry BB, I should have been more specific. Did you do any before and after comparisons. Like , was there any noticable effect on the handling, braking, driveability of the car?
Cheers
Muz
https://www.sau.com.au/forums/topic/131192-balancing-car/#findComment-2429581
Cheers
Muz
What we are doing by corner weighting a car is making sure that it puts its weight down evenly, the two front tyres carry the same load and the two rear tyres carry the same load. The total diagonal weights are even.
For an un-corner weighted car, think of a rocking table, with 1 leg shorter than the other 3. When you lean on one corner (turn left round a bend), the table (car) goes bonk until that short leg hits the floor (the spring takes the load). Now lean on the other end (turn right around a corner), the table (car) goes bonk until that leg hits the floor (the spring takes the load).
So when you have 2 corners, one after the other, you get instability (bonk) whenever you turn the steering wheel. This makes the driver feel like the car is slipping just as he turns the steering wheel, he has no confidence. It also unsettles the car, the tyres don't like the sudden hit of load (bonk) and they do actually slip a little.
How much difference does it make? It's like a dyno tune, if the weights are out by a lot, then it makes a lot of difference. If they only out by a little bit, it makes very little difference.
:P cheers ;)
https://www.sau.com.au/forums/topic/131192-balancing-car/#findComment-2429848
Thanks SK (legend). I kind of thought it would be that or something very similar to what you have described. I will definitely be having this done when the Tein's are installed. Just one more question (sorry), does a drivers weight impact upon this setup or is it a case of only diagonal weights being critical and not same side?
cheers
Muz
https://www.sau.com.au/forums/topic/131192-balancing-car/#findComment-2430081
Yes the driver should be sitting in the car with the expected fuel load when you do the weighing.
But is this for road or circuit use? because on the road you have passengers, very different fuel loads, stuff in the boot etc etc
https://www.sau.com.au/forums/topic/131192-balancing-car/#findComment-2430102
Yeah I had it done on my toymotor. Results were amazing. I installed it myself at first and it was very weird. Spring pre-loadings were also tampered with before I opened the box so that certainly didn't help. Afterwards the car was much more composed.
https://www.sau.com.au/forums/topic/131192-balancing-car/#findComment-2430434
Yes! it presents a conumdrum doesn't it. I was specifically talking about road use.
cheers
if you are talking about road use then it may be a waste of time. just set the heights as accurately as you can.
https://www.sau.com.au/forums/topic/131192-balancing-car/#findComment-2431150
1. So what about cars with non adjustable height? Nothing much can be done eh?
2. And what about FWDs?
3. Would their ass be on the ground and nose up in the air?
1. Use spacers
2. No difference to RWD or 4WD. Many front wheel drive cars have better front to rear weight distribution than a Skyline with that great lump of RB cast iron in front of the front wheels.
3. No, the front left should carry the same weight as the front right and the rear left should carry the same weight as the rear right. More precisely the diagonals should weigh the same.
:/ cheers :/
https://www.sau.com.au/forums/topic/131192-balancing-car/#findComment-2432488
  • 1 year later...
What is the best front to rear weight distribution has anyone achieved for the skyline?
Mine was like 900kg (60%) front and 600kg (40%) rear.
From memory the R32GTST was around 650 (55%) and 550 (45%)
Cheers
Gary
https://www.sau.com.au/forums/topic/131192-balancing-car/#findComment-3935014
Thanks SK and Duncan
I will need to take some more weight off my car in the future. My current weight is still too heavy. My rear left is a around 40kg lighter than the rear right. Is this common in the gtr? Can you guys offer some suggestion?
https://www.sau.com.au/forums/topic/131192-balancing-car/#findComment-3936413
The rear left being lighter is normal, the driver is on the RHS after all. The usual corner weighting adjustment is to shorten (take weight off) the RHS rear to compensate.
Cheers
Gary
https://www.sau.com.au/forums/topic/131192-balancing-car/#findComment-3937388
Forgive my noob comment, but how do they take weight on or off, is it just by adjusting the height slightly at each corner?
thanks guys
Obviously the best way to adjust the corner weights is to move something. An example, moving the battery from the front (which is the heavy end) RHS (which is the heavy side) to the rear LHS makes a useful difference. But when you run out of things to move, then adjusting the height of each corner is the go.
Cheers
Gary
https://www.sau.com.au/forums/topic/131192-balancing-car/#findComment-3938241
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
    • Thank you so much for the help
