I got an eye-full of the sedan version of a 1997 Galant VR4 on J-Spec and I must admit, I reckon it's a cool looking car, seems practical-ish too with the whole 4 doors thing. My question, does anyone here have one or know someone that has one. Are they a decent car? I read they make over 200kw's stock and are 4WD but what's the weight like? Do they mod up OK are they hard to get parts for, do they use the evo engine etc etc etc. I currently have a 96 Series II 33 (as Seen in my avatar ) so would be comparing to that.
Cheers
Dan
https://www.sau.com.au/forums/topic/131362-galant-vr4/
I don't have one, but have driven the wagon version called the 'Legnum VR-4'. It was an auto so didn't really get a feel for it as what I could've with a manual, but for what it is it's (the Galant) a great alternative to a Toyota Mark II or R33 sedan. Being front wheel drive based 4WD you do get that typical feel of understeer, but straight line performance is on par with the others mentioned, and on paper really should go as well as an Evo 5/6 but I don't think so.
As for the Galant you can't really argue with those looks, it's very well proportioned. But it fails miserably for aftermarket support compared to Skylines, theres only a handful of companies in Japan that really support the Galant/Legnum and even then they aren't exactly cheap. Try finding stuff for Mitsu GTO's and adapt... Yahoo will come to the rescue somewhat too. Other thing is the engine is a trasverse mounted twin turbo so with the limited room and piping everywhere you might find it hard to find someone who enjoys working on them.
Some specs:
Chassis: EC5A
Engine: 6A12
Capacity: 2498cc
Type: Quad cam 24 valve V6 twin turbo
Trans: 5MT/4AT
Power: 280ps @ 5500rpm
Torque: 37.0kg/m @ 4000rpm
Weight: 1480kg
https://www.sau.com.au/forums/topic/131362-galant-vr4/#findComment-2430338
I think they would great daily and a very reliable car but i reckon they would be hard to source parts from wreckers in Australia if parts needed to be replaced.
Untill people start importing these VR4s and driving them around and people are after parts out of it i dont think wreckers will be importing VR4 parts in a rush till there is market for them
Edited by MFC05
https://www.sau.com.au/forums/topic/131362-galant-vr4/#findComment-2440467
i think they are nuts, a real sleeper! in stock trim the 2.4L twinturbo v6 runs a 14.0 second 1/4 mile
well the r33 is quoted as pretty much that as well..
The Galant, is a larger engine to the EVO ones, which you'd think would translate into more power. I guess a lack of parts doesn't help.
The later model engines (6G75) were similar to the same one seen in the mitsu 380.
https://www.sau.com.au/forums/topic/131362-galant-vr4/#findComment-2440848
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
    • BTW I measured the jack I have, it is 70mm at the saddle but you only have about 700 until it returns to 150mm high at the cylinder so it is good but no magic bullet.
