Hello Peoples,
I have sooo many r33 parts for sale so here is a list of them (pics provided where applicable).
Full R33 Dash $450
Stock Front Headlights $200
Front right quarter panel
Bonnet $200
Grill$100
Rear Spoiler (the black has carbon fibre through it) $300
Rear lights (both of them)
The part between the rear lights (the bar with SKYLINE on it)
Center Consol $50
Stock Rear Bar $150
Rear Bar Reo$100
Parcel Shelf$50
Rear window
Side quarter windows (both sides) $50 EACH
Cat back exhaust (center part has been bottomed out and it fair flat but end is good) $400
Drivers door (with full interior on it) great condition $500
Passenger side door trim only$75
Rear seats$200
Side skirt (driver side only)
Full rear cradle including LSD (lsd type and condition unknown)
Plus ANYTHING from a halfcut minus the engine gearbox loom etc etc and calipers
Lots of interior parts
PM me for more details or u can ring my mobile on 0403176783 (yet uni student so it may sumtimes be on silent)
cheers
Browny
Edited by Browny31
https://www.sau.com.au/forums/topic/131370-sa-r33-parts/
  • Replies 45
indicators r gone....
foggies ill check condition of. if they r good .... $75
Im hoping you mean the S2 front bar foggie/indicators.
Ill take it for $75. Does this include post? If not how much for post to NSW 2567?
Any pics?
https://www.sau.com.au/forums/topic/131370-sa-r33-parts/#findComment-2431857
drivers door trim will only be seperateed if a buyer wants to buy JUST the outside of the door. otherwise i wont seperate it.
ahh ur talking about the ones in the bar..... yes ther are s2 and they r still there. ill take pics sat for everyone that has asked
https://www.sau.com.au/forums/topic/131370-sa-r33-parts/#findComment-2431876
    • Did and sync timing with light
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
