Mate thanks for that im so confused. I have read that we should not accept anything under 130..
After speaking to the mechanic and then another mechanic. they both told me that because it is a turbo engine they have a low compression..
https://www.sau.com.au/forums/topic/131691-urgent-help/#findComment-2439543
yeh compression ratio is low...but cylinder compression is different to your CR. They are probably relative to eachother, but most RB's should be around those figures. But most std ones that have been around or thrashed will more then likely have low compression....rings are shagged :P
https://www.sau.com.au/forums/topic/131691-urgent-help/#findComment-2439583
Hey guys im just about to put a deposit down on a skyline...
i just had it tested and everything is good..
the compression test came back 120 for each cylinder..
Any opinions... is 120 ok or not acceptable at all.
What model?
150-160 is OK for R33GTST (RB25DET)
130-140 is OK for R32GTST (RB20DET)
Compression tests are a bit unreliable for absolute numbers, depends if the engine is properly warmed up, how good the battery is etc. Compression test is really only good for picking one (or two) cylinders being down on the rest. Leak down tests (wet and dry) are a more accurate check.
:P cheers :P
https://www.sau.com.au/forums/topic/131691-urgent-help/#findComment-2439584
thats low....maybe not in someone elses books but in mine it is. A cold test i would want it to be around 150-160 no less then that or your in for hard starts and poor economy and lack of power and lots of blow by...eventually.
https://www.sau.com.au/forums/topic/131691-urgent-help/#findComment-2439658
just got the report back from the Mechanic. After speaking to the guy at Nismo he said that it depends how the guy did the test. was it cold or warm was the battery good. But this is what it got.
1. 120
2. 120
3. 120
4. 120
5. 120
6. 120
just reading through all the hundred of compression threads it still up in the air. Some say as long as the number is even across all cylinders its ok.
thanks again for the help
https://www.sau.com.au/forums/topic/131691-urgent-help/#findComment-2440129
bro i've gota ask you about this LEAK DOWN TEST wat exacty is it?
Can anyone advise if that's a little TOO even? A perfect 120 on all cylinders?
i was thinking the same thing that is abit too even ey
https://www.sau.com.au/forums/topic/131691-urgent-help/#findComment-2440461
1. 120
2. 120
3. 120
4. 120
5. 120
6. 120
Have you driven it yet?
It sure looks suspicious all to be that spot on.
I was wondering if work load such as pulling or carting things around could have a greater even load
on the way the cylinders wear, lots of high constant speed could do this aswell i would think.
This may explain the results if they are correct.
If a car has been thrashed , usually there are particular stress caused on some cylinders and wear
and compression are uneven.
Check out to see if those km's are genuine. then look for wear on the boots etc.
Offer them $2000 less and have the thing rebuilt if you are concerned.
If the car is clean and looks like it has been taken care of ,test drive it ,get it checked once over and if you are happy , buy it. :)
https://www.sau.com.au/forums/topic/131691-urgent-help/#findComment-2440477
Thanks again for all the info. I had another look at it to day and it is clean couldnt see any oil any where and the engine bay looks good.
Couldnt take it for a test drive today cause he was the only one in the office.
I got the car VACC tested. They said the only thing wrong with it is that it needs the radiator flushed and thats all other wise they gave the car a good rating..
Again guys thanks for the help. Sorry to clog up the forum with more compression posts.
Will keep you posted if i bu it or not
https://www.sau.com.au/forums/topic/131691-urgent-help/#findComment-2441177
Yeh i agree...sounds a little too suss to have 120 across ALL cylinders and yes i belive this is very low. Again like Nismo said it will depend on the conditions the test was done (wam/cold)
I did comp and leak down test on my old neo rb25 (cold) and got these figures
1)120
2)165
3)160
4)155
5)150
6)155
Pulled apart engine and piston 1 was FRIED as a mofo ------> SEE PICS BELOW
I would be VERY careful. Could turn out to be a lemon and cost you big.
My 2 Cents
Edited by FSTR32
https://www.sau.com.au/forums/topic/131691-urgent-help/#findComment-2441195
    • When I said "wiring diagram", I meant the car's wiring diagram. You need to understand how and when 12V appears on certain wires/terminals, when 0V is allowed to appear on certain wires/terminals (which is the difference between supply side switching, and earth side switching), for the way that the car is supposed to work without the immobiliser. Then you start looking for those voltages in the appropriate places at the appropriate times (ie, relay terminals, ECU terminals, fuel pump terminals, at different ignition switch positions, and at times such as "immediately after switching to ON" and "say, 5-10s after switching to ON". You will find that you are not getting what you need when and where you need it, and because you understand what you need and when, from working through the wiring diagram, you can then likely work out why you're not getting it. And that will lead you to the mess that has been made of the associated wires around the immobiliser. But seriously, there is no way that we will be able to find or lead you to the fault from here. You will have to do it at the car, because it will be something f**ked up, and there are a near infinite number of ways for it to be f**ked up. The wiring diagram will give you wire colours and pin numbers and so you can do continuity testing and voltage/time probing and start to work out what is right and what is wrong. I can only close my eyes and imagine a rat's nest of wiring under the dash. You can actually see and touch it.
    • So I found this: https://www.efihardware.com/temperature-sensor-voltage-calculator I didn't know what the pullup resistor is. So I thought if I used my table of known values I could estimate it by putting a value into the pullup resistor, and this should line up with the voltages I had measured. Eventually I got this table out of it by using 210ohms as the pullup resistor. 180C 0.232V - Predicted 175C 0.254V - Predicted 170C 0.278V - Predicted 165C 0.305V - Predicted 160C 0.336V - Predicted 155C 0.369V - Predicted 150C 0.407V - Predicted 145C 0.448V - Predicted 140C 0.494V - Predicted 135C 0.545V - Predicted 130C 0.603V - Predicted 125C 0.668V - Predicted 120C 0.740V - Predicted 115C 0.817V - Predicted 110C 0.914V - Predicted 105C 1.023V - Predicted 100C 1.15V 90C 1.42V - Predicted 85C 1.59V 80C 1.74V 75C 1.94V 70C 2.10V 65C 2.33V 60C 2.56V 58C 2.68V 57C 2.70V 56C 2.74V 55C 2.78V 54C 2.80V 50C 2.98V 49C 3.06V 47C 3.18V 45C 3.23V 43C 3.36V 40C 3.51V 37C 3.67V 35C 3.75V 30C 4.00V As before, the formula in HPTuners is here: https://www.hptuners.com/documentation/files/VCM-Scanner/Content/vcm_scanner/defining_a_transform.htm?Highlight=defining a transform Specifically: In my case I used 50C and 150C, given the sensor is supposedly for that. Input 1 = 2.98V Output 1 = 50C Input 2 = 0.407V Output 2 = 150C (0.407-2.98) / (150-50) -2.573/100 = -0.02573 2.98/-0.02573 + 47.045 = 50 So the corresponding formula should be: (Input / -0.02573) + 47.045 = Output.   If someone can confirm my math it'd be great. Supposedly you can pick any two pairs of the data to make this formula.
    • Well this shows me the fuel pump relay is inside the base of the drivers A Pillar, and goes into the main power wire, and it connects to the ignition. The alarm is.... in the base of the drivers A Pillar. The issue is that I'm not getting 12v to the pump at ignition which tells me that relay isn't being triggered. AVS told me the immobiliser should be open until the ignition is active. So once ignition is active, the immobiliser relay should be telling that fuel pump relay to close which completes the circuit. But I'm not getting voltage at the relay in the rear triggered by the ECU, which leaves me back at the same assumption that that relay was never connected into the immobiliser. This is what I'm trying to verify, that my assumption is the most likely scenario and I'll go back to the alarm tech yet again that he needs to fix his work.      Here is the alarms wiring diagram, so my assumption is IM3A, IM3B, or both, aren't connected or improper. But this is all sealed up, with black wiring, and loomed
    • Ceste, jak se mas Marek...sorry I only have english keyboard. Are you a fan of Poland's greatest band ever?
