Changed My 33 Climate Control Lights To Blue(pics)
they're really not that much more expensive than the ones you buy at autobarn...$14 for 2...so $7 each or $10 for 1... not much difference :D
yeah ur right...just bought 5 x white and 5 x blue for both cars...should be fine. My issue is the directional light from the LEDS...this should help even it out..
  • Replies 75
installed some of these 2nite. They fix up the unevan problem pretty well, the cluster is heaps brighter now :)
these r the ones i bought, c how they have 4 LED's facing all direction's?
http://www.superbrightleds.com/specs/bulb_specs.htm
installed some of these 2nite. They fix up the unevan problem pretty well, the cluster is heaps brighter now ;)
nice...I'm still waiting for mine to be delivered. looks like it will be good.
and a picture of mine using normal style led's...note the brighter spots...the bits that look dull are pretty much as bright as a normal cluster, they just look duller because of the brighter spots...
i need some1 to help me with this ;)
Its VERY easy to do mate.
take out the cluster, flip it round, take out the 5 stock lights and plug in some parker style LED's
put it back in and you're done :)
wowo good results with the new style leds. The other pics resemble efforts I have done before and I just went back to globes cos it pissed me off too much. Should get mine this week and I will take a pic. I got white and blue...blue for the line and white for the FTO as I have blue/red dials...will look awsome.
Changed mine from regular LED's to the ones from America today...no bright/dull spots. completely even across the cluster.
Only downside to them is they are a Slightly lighter blue to the ones I had in there, which matched my gauges/headunit perfectly...but the new ones aren't far off :D
Photos: These are the American LED's
Nice even spread. :)
compared to the old normal LED's in the same dash...
and here's the new ones showing the slight color difference to my gauges
Not very noticeable :D
nice1 dezz...yeah I took a pic and mine look they same as yours but in real life I rekcon they looks better.
At least ur guages are blue...mine matched the stock lighting color...so i have to change them now :D
pretty sure its not the LED's kon. mine were like $14 for 2 (so hardly cheaper than yours)...
its the layout of the light spreading plastic on the back of the cluster
so it was the low quality LED's u had in before?
i wouldnt call them low quality. just a different layout.
justin had everyday single Narva brand LED's and i had a different brand with a triple LED layout on the top.
both showed exactly the same light spread...the ones from america have a better design
