Hi everyone - more wheels for sale!!
*UPDATE* *AF-FLUX WHEELS SOLD! LINEA SPORT WHEELS STILL FOR SALE!* (30/11/06)
2x LINEA SPORT wheels with chrome dish - Specifications:
- Dimensions: 17" x 8.0" wide
- Offset: +32
- Tyres: 215/45 zr17 Yokohama Grand Prix M5 (not a lot of tread - could pass as roadworthy)
- Condition: Note pictures
- PRICE: $250 O.N.O
For inspection/queries please call Tony on 0405707680
Located in melb - pick up preferably.
Cheers,
Steve.
Edited by R32_GODZILLA
https://www.sau.com.au/forums/topic/131942-2-pairs-of-17-inch-wheels-for-sale/
  • 3 weeks later...
+40. is that a GTR offset? Will it fit R32 GTSt?
thanks.
Hey Russell - in regards to the offset, i'm not sure whether it's the same as the GT-R. What i do know is that the pair came off an R33 GTS-t if that helps?
If anyone can shed some light on GT-R offset that would be good :ermm:
Cheers,
Steve.
I'll check out if they will fit my 32 GTSt and get back to you.
Also where in Melbourne?
No problems mate :happy: My friend is located in the Western Suburbs - i'm advertising his wheels for him.
*edit* If you cannot retrieve any information on the offset, i'll try and find time to fit those wheels on my car (rear) and see how i go.
Cheers,
Steve.
No problems mate :P My friend is located in the Western Suburbs - i'm advertising his wheels for him.
Cheers,
Steve.
Thanks.
I'm at Bathurst this weekend but I'll check this thread again when I get back. If you put them on your 32 please take some pics.
Russell
Its far from being GTR offset...+40 more suited to GTSTs etc...
Yeah you're right. I just read up about it. The more + the offset is - the more it sits in the guard.
Found this on another thread....
offset is: backspace - (width / 2)
backspace is the distance from the rim to the surface that mounts against the hub.
The offset of a wheel is the distance from its hub mounting surface to the centerline of the wheel. The offset can be one of three types.
ZERO OFFSET
The hub mounting surface is even with the centerline of the wheel.
POSITIVE OFFSET
The hub mounting surface is toward the front or wheel side of the wheel. Positive offset wheels are generally found on front wheel drive cars and newer rear drive cars.
NEGATIVE OFFSET
The hub mounting surface is toward the back or brake side of the wheels centerline. "Deep dish" wheels are typically a negative offset.
Thanks.
Russell
No problems. I'll talk to my mate to try and organise for sunday to be the day to place the wheels on and take some shots - *monday latest*
btw, thanks for the offset info. :(
Cheers,
Steve.
Pictures of the AF-FLUX 17x9.0 fitted on my R32 GTS-t are here. This will give you the general idea on the offset (+40).
IMO they sit perfectally with the gts-t guards, and look great :(.
:whistling: we figured out we got the rotation wrong after whe fitted the first wheel - we weren't going to drive around with them on, so we figured to leave them, as it gives you the same general idea.
Cheers,
Steve.
  • 3 weeks later...
    • Cheers. Skyline is back on the menu, can’t get rid of it. It’s like a child you don’t want, or herpes
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
