Does anyone use an Apexi air pod filter are they worth the money and if you do use one do they make a difference.
i have one installed and trust me they wont disapoint ya and according to Apexi, there is a 10% reduction in pressure drop by utilizing an upper and lower funnel. The Apexi Power Intake reduces air turbulence within the filter and creates smooth air flow into the throttle body. check this website out
http://mkiv.com/techarticles/filters_test/2/
Thanks mate good info.
this can be bolted on straight into the AFM correct?
http://cgi.ebay.com.au/ws/eBayISAPI.dll?Vi...A%3AIT&rd=1
it will if it is the correct one for your car
500-A022 is direct bolt on for the r33,r32,z32,r34 AFMs
Q45 is the 500-A021
i find that with the apex-i pod filter - i can feel the turbo more on the passenger seat....i dont know why though....but the sound is sooooooooooooooo cool!! :(
does the sound from the apexi pod sound like a huge sucking vacuum. coz that's what my intake sounds like.
dunno what brand mine is. it's a mesh pod, looks kinda similar to the apexi.
Yeah its a vacuum like noise - but its not too loud. I just notice though that you can feel the turbo more with that on for some reason. Same thing with the car i test drove at kamikaze, All it had was the pod on it, and i could really feel the turbo kick in......
I dont think you clean them at all...they should last for ages. the linked site says its "zero maintenance"
Before you buy off ebay consider Kudos's offering, same price and aussie delivered, not a shonky guy and express posted to your door. cant complain with that. Just got mine last week and im uber happy. Better than the HKS one i had on b4
just got mine in a few days ago. Seems more quiet then the HKS one, but I think I feel a bit more 'power' in it? Or maybe cos its the cold day.... :ermm:
very noisy pod, makes noise on the slightest throttle opening, zero maintenance means that when it gets dirty u chuck it out and buy a new one, so not cheap in the long run. didnt feel any power increase.
Edited by siksII
