My car (95 R33 GTS-t) started missing the other day. At all different engine speeds - from idle to redline. Sometimes you would put your foot down and have nothing for a few seconds, then suddenly it would kick in.
I thought it was the coils, so I taped them up. The car started ok, no missing. The next day, half an hour into the drive it happened again. Then it cut out completely and refused to start. It turns over, but doesnt fire.
Got it towed to the mechanic, but they cat seem to see where the problem is.
- Battery has been fully charged.
- sprayed a bit contact cleander on the AFM
- have tried swapping ECU, CAS, coils. Spark plugs are fine
- have checked all fuses, power supply
My mechanic says "basically there is no signal from the ECU to the coil"
It is not a fuel related problem - definitely ignition problem.
Its being booked in at an auto-elec tomorrow, but hopefully someone has had a similar problem before and knows what it is.
I cant do a diagnostic test cos I cant find the stupid grey plug behind my dash.
https://www.sau.com.au/forums/topic/132006-car-wont-start/
:( had similar problem replaced the ignitor and it ran perfect until i fryed another ignitor which apparently isnt to comon. In the end turned out my coilpacks shat themselves and were frying the ignitor. Not sure how that worked i think it was sending voltage back to the ignitor and frying it. In the end got another ignitor replaced the coilpacks and the problem went away. good luck
https://www.sau.com.au/forums/topic/132006-car-wont-start/#findComment-2453642
    • Have a vb in honour of the car comming back
    • It was a great, but typical track day, and some VB was ingested at the night time debrief 🤪
    • And so, to round this out, I couldn't be happier to confirm @MBS206 has decided to buy the car. He drove down from sunny QLD with a trailer last week and it is off to its new home today. I'll let Matt confirm on next steps but I understand broadly that the plan is to leave it pretty much as is, and just get some quality wheel time with a nicely balanced car that is pretty much track ready. There are a few a jobs still to be done first but nothing too major and I think its a very smart buy Dinner last night at the Paragon with a round of VBs (mostly) for Neil
    • Well, 50 pages and the end of a chapter for this car. We took it out for a shakedown at Wakie yesterday, and everything went well. There were a couple of niggles: - Oil cooler fitting leak - tightened, cleaned, stopped leaking - Radiator cap overflow fitting was leaking....Mark called it, the overflow fitting was threaded in and not tight....tightened, tested and held pressure - Small oil leak at the rear of the block, probably the turbo oil feed - too hot to get at it comfortably but probably just needs to be nipped up - leak at the driver's side rear brake line where it meets the hardline. Fitting wasn't loose, so Matt backed it off and back on, no further leaks - there's also a leak somewhere on the top of the fuel tank, maybe that cross over fuel line - that was has been left to fix when its on a hoist Otherwise than those niggles the car went great, turned great and stopped great so it was a very successful day out. I'm always really nervous when a car first hits the track after a long break, especially with a brand new engine as well but it was great. VID-20251011-WA0007.mp4  Big thanks to @The Bogan who dropped by and helped out, @MBS206 and my nephew Lachlan the apprentice.  Neil's wife Mel also surprised the hell out of all of us by dropping by; she's up in Tamworth these days but was travelling to Melbourne so had plausible deniability for turning up at the garage, it was great to see her but also obviously a bit sad all round.
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
