Hey gents and lady.
Getting my handbrake shoes changed tomoz and just wondering what they interchange with ?
I have a rear disk for normal brakes and drum for handbrake. Also car was NA from factory so I thought perhaps NA S13 ?
Any input would be greeeeat! Thanks :P
https://www.sau.com.au/forums/topic/132015-handbrake-shoes/
s13's dont have drum handbrakes so that rule's that out. I'd be looking at s14's or r32's or something... but pull yours out and find something that matches them.
have you done urs? i remember something about you wanting to tighten the handbrake so thought you might have done them.
Im thinking R32 atm :S
https://www.sau.com.au/forums/topic/132015-handbrake-shoes/#findComment-2445253
here is a pic of them installed (obviously without the disc on)
Turns out the shoes were ok but they were out of alignment and weren't grabbing the drum properly.
Had to get the rear pads replaced after been told by another place on saturday that they were fine.
Grrr
Also, do you notice a difference with the uras ones ?
https://www.sau.com.au/forums/topic/132015-handbrake-shoes/#findComment-2447646
well... i bought the URAS brake shoes... they're the same as 32 and most other drum applications...
I have to ask is there anything you can do with the uras ones you can't do with stockies or is the marketable factors of uras ones that they last longer or something?
https://www.sau.com.au/forums/topic/132015-handbrake-shoes/#findComment-2451161
s14 is disc handbrake... just like sils
r32/r33 are the same
uras ones would be good for supposed performance enhancement
so is this true for the s14 disc brake ? Do they bolt on to the rear of the ceffy? direct replacement?...and are they twin piston likie the 32s and 33s?
thanks ...sorry for going off topic a bit
https://www.sau.com.au/forums/topic/132015-handbrake-shoes/#findComment-2453098
direct replacement
modify handbrake cables and thats it...
single piston s14/s15... not twin like 32/33
https://www.sau.com.au/forums/topic/132015-handbrake-shoes/#findComment-2453553
to me it looks the same... put it this way - it wont be a downgrade... youll have 5 stud and larger rotors
the other thing you can do
use the s14 stub axles and hubs... then get 32/33 rear rotors... and use something that runs disc handbrake that isnt single pot caliper...
OR just use your standard stub axles - use 32 hubs... you get to keep your drum handbrake setup... and use 32/33 rotors n calipers (what ive done)
direct bolt on! less muckin
https://www.sau.com.au/forums/topic/132015-handbrake-shoes/#findComment-2457034
yea well at the moment i am staying 4 stud .........i already have wheels(which are awesomeand 4 stud)...yeas i could sell and go through all that agin but i really cant be bothered ....its cheaper to stay 4 stud at this point in time ...thats why i was just talking about callipers not hubs ...........in the end i may go 5 stud but ............but its just going to be a pain in the arse now ....
https://www.sau.com.au/forums/topic/132015-handbrake-shoes/#findComment-2457890
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG has not responded to my emails so far since purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
