Hi guys..
Posted this earlier today but it seems to have randomly vanished so I'll start another!.
I was washing my car before, and some of the white paint stuff that's used for drawing your numbers on at deca flaked and and seems to be stuck to my paint.. So I have little white specks all down the gaurd of the black car :D:(:O... does anyone know the easiest/best way to get this stuff off without destroying the paint at all??
Cheers.
https://www.sau.com.au/forums/topic/132128-white-number-paint-from-deca/
tongue works wonders :O
Dont use kitchen towel like my first efforts at the November DECA, ended up with the window being more of a mess than with the number on there! BTW ordinarilly I wouldnt have considered using it but it was all that was available in the cabin and Viva is supposed to be strong!
I normally just scrape it off with a blade. Mine are still on though at the moment until I get the car back.
LOL wtf are you all on about? Bit of water on an old towel, came off no problems.
If i used something that cost money the car might get the idea that I care :O
Dave dont be silly the car knows that you dont care!!!
    • New CAS just turned up from NZ Wiring. Looks like a nice bit of gear.  So, yeah. Triggered, bro. Realised I may as well do the cam belt while mucking about with it so will order one of them.
