i think in the near 4 years ive owned my r33 i've found having 2 doors annoying probably 3 to 4 times. the 4 door models dont look as good as the coupe imho. but its personal perference of course.
I plan to buy an R34. I really dont mind 2dr or 4dr. Obviously, the 4 dr has a bit of convenience with access to the rear seats. But, are there any other main differences? Is the wheel base longer?
2 Door will hold its value better and you will look cooler too :P:D
everyone knows that if you buy a 4 door your cool factor is instantly elevated to that of D1 drifter Nomuken because 34 4doors are just one of the better looking 4 door skyline out there.
So true..
I love my 4 door in saying that i would also like a coupe
Go with what will suit your daily drive..
eg.. do ya have a large family is it your only car are ya after performance so on and so on..
Four door will not retain it's value anwhere near as well as a two-door. They also look slightly awkward.
So far the general feedback is 2drs hold value longer, and they are cooler. I spose its cos there were soooo many 4drs made. I wonder if that will change. I'm living in Japan at the moment and Nomura Ken is fairly popular. He's marketing the "Monkey Magic" brand well through Uras, and I see a lot of 4drs with the D1 kit.
So, in the end.........it does come down to appearance and convenience...?
    • Sorry I haven't been following all the detail, so you may have tried this. Does it idle with the tiniest bit of throttle you can add? You've mentioned the IACV, does it have an AAC valve and have you adjusted it at all (ie, screw the idle adjust screw all the way in, then back it out a couple of turns until idle is stable)?
    • My bad, I unplugged the one underlined in red instead of yellow before. With the car started, after unplugging the IACV (the one underlined in yellow), it idled at around 400/500 for 3 seconds before stalling. Attempting to start the car without the IACV will not start the car.   It does stutter and sputter for around 5 seconds before dying. However, immediately after starting it, you can already hear some slight sputters from the exhaust.   It won't start with the AFM unplugged. If it is when the car has already started, it stalls in a few seconds.   Yesterday, I did take some logs using Nistune of 3 scenarios. Car idling till it stalls Car idling and unplugging the IACV Car idling and removing the AFM I also have some previous logs of when the Car is idling till it stalls and when driving and it cuts. I am not really knowledgeable enough to understand what to look for. After every test, car idles rougher and rougher, until I have to stop. It will be fine the day after.
    • There is no difference between a 17x8 and an 18x8. The total diameter of the tyre needs to remain +/- the same (so you don't mess up the gearing, speedo reading, and clearance when turning front wheels..... so you just need to use a lower profile tyre on th 18 than you do on the 17. /rocket surgery.
    • I thought the same to start with. But then I thought it was one of those LCAs where the end of the ARB goes through a bushing in the LCA itself, instead of having an end link.
    • Yeah - I mean, go the other way. Smaller range. Not larger.
