howdy people, well i'm not freakin happy, my msn got hacked again.
i dunno how but it did. anywayz the scums changed all my secret
questions, and my alternative email so i can't get back into it.
somehow i have to hack back into it, any1 know how i can do that??
also if any1's talking to you on my account, it's obviously not me.
https://www.sau.com.au/forums/topic/132183-help/
I think it's time for you to install some spyware buster programs in your computer. If they can get your account password to MSN, they can get your other passwords as well (from internet banking transactions, ebay, paypal and etc....). A friend of mine actually had the same problem and a few days later his bank account was hacked. AUD2K gone!
Edited by bixby
https://www.sau.com.au/forums/topic/132183-help/#findComment-2448925
ahh crap, i don't think we have any spyware programs.
got any you'd like to suggest i use??
great if they get into the bank accounts and ebay accounts
my parents are gonna kill me >_<
I don't run any spyware on my comp at all.....
I just use Nod32!
Best program period! Google it and check out the reviews, literally stop anything and everything dead in its tracks!
Just for kicks i d/l and installed the best spyware program on the market and whatr do you know after a complete massive scan it found nothing!
Nod32 FTW!
https://www.sau.com.au/forums/topic/132183-help/#findComment-2449025
try panda software - its a virus scanner + spyware program
otherwise if you already have a virus scanner, get windows xp 2 (i think thats what I got - my bro installed it for me) - thats got a built in spyware
What we need is a program made up so that the hackers, when they hack in, get infected automatically, and all their secret stuff comes back to us - then the fun begins.....
https://www.sau.com.au/forums/topic/132183-help/#findComment-2450175
so u still want to be doing a thorough clean maybee even install
Netlimiter PRO this has a inbuilt firewall that works if a programs wants to send back to the internet NLpro will catch it and you have to give it permission
http://www.netlimiter.com/ << actual download
https://www.sau.com.au/forums/topic/132183-help/#findComment-2453063
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
