  • Replies 51
what do you guys think of cutting the standard plenum and running the throttle body from, the front it would reduce heaps of pipe work and make it more responsive and if done what vacume pipes could be disgarded
Edited by xxx_25L
hahahah, you flew right off the rails with that one! You quite clearly missed my point, but you almost got there. Good try.
Don't be so defensive, this is a discussion forum, so discuss. Encourage conversation, don't put people down.
Try thinking about what people say, rather than interpreting things so black and white. What makes you so sure that the meaning you took from my statement was the one I intended?
Lastly, if what I was thinking was "stupid", I would not have thought it necessary to add it to the "discussion".
:D
now that's a stupid response!....there's money in everything..geez u might as well say why upgrade your turbo or why are they selling them..to make money duh!... lets just do research for the sake of it...hahahahhahaha.....ffs...
Edited by Turbo Tits
:laugh:
as u can see i was laughing and im still laughing....hahahahahahahah im not defensive im discussing the topic on hand..hahahahahahha....
i have 1 tommie inlet cam (256) so thats good then.
i tink i will setal with a isp (arial) plenum they seam to be the pics of the group.
i think i could make good power with the standard manifold but i wanna make power with as litle boost/effort posible.
the less restriction the less boost so i mite go 1 of them
Im currently in the midst of doing a full GTR ITB Conversion to my RB25 including custom manifold (leaning towards a plazmaman plenum) will keep you posted on before and after results if you are interested.
I know they wont be specifically related to the plenum alone as the ITB's are bound to make some difference but at least it will give you some scope of a real world application.
Turbo = T67-25g - Currently pulls around 500rwhp
keep us updated.
also i wanna know how it all fits up and all that jaz chuck up some pics when your done.
the latest zoom mag has 1 of there plenums in it and it looks ok but it all depends on how it works
keep us updated.
Ive had to use a CNC machined adaptor to make it fit correctly ($500 from japland) and switch my fuel rail and injectors for GTR Items to suit... will definitely keep you posted. SHould come up a treat once its done.
So its 10psi and not 8psi now eh?
Which version of the story are we to believe?
But you are in the US remember, the figures are somewhat "higher", your 50rwkw is around our 30, which then (going to 10psi/management) is whats expected
Have you ever done this same build up and tested it on the same exact dyno to get readings? I have.
I am not sure if you read my first post correctly or not, but I said that it was at 10 psig up to about 6K, then all the way to 7500, it fell to 8 psig. At 8 PSIG at 7500, it made 310rwhp, which is 235rwkw.
You are in America.
Its impossible to compare, especially 235rwkw from 8psi.
If you wanna do accurate testing, bring the car over here and you'll see your 235 fall to around 180-170
With 235rwkw you'd better be dipping WELL into the mid-12 sec brakcet.
Look forward to you strip results. But i suspect you wont get better than a mid-low 13.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
    • Thank you so much for the help
    • Yes it is ATF. I quote @Duncan "it takes a good synthentic auto trans fluid like Castrol Transmax Z" It's not a diff. It's a transfer case. Totally different thing. Yes, fluid will come out the sender hole. No you do not really need to drain it. Just pull the old, quickly poke the new, clean up and top up. But realistically, you should probably take the opportunity to change it anyway.
