Which is a Rev Happy Engine?
87 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
Do you have an in depth explanation? Im always looking to learn new things.
Yes please do educate us on why a 2l 4ycl will be less willing to rev than a 2l 6cyl. For that 4 cylinder to drive at 100km/h it will be revving higher, as it accelerates its gearing will mean it will require gear changes more often, it is a smaller engine which mean there is less to spin up, but i guess im wrong. I look forward to seeing why.
how rev happy an engine is has nothing to do with the displacement... its a function of the borexstroke ratio...and to a lessser extent the cam profiles...how reliably it does it comes down to how strong it is. generally a short stroke motor will be more 'rev happy' than a long stroke motor - but it will sacrifice this for torque....
thus the true answer to the question is go and do some research on the bore stroke of all those engines and then look at where on the rev scale they make peak torque and power and also what the rev limiter is set at......
and r32line - the reason for the difference between the 4cyl 2 litre and the 6cyl 2 litre is generally because they have spread the capacity of 2 litres across 6 pistons - and chosen to keep the stroke short - compared to the 4cyl its (prob) a very different borexstrok ratio...
ps ... also changing the gearing ratio will effect things allot.... an old trick is to drop in a shorter ratio box, while you lose some top spead you have better acceleration and a somewhat 'revier' car to drive
Edited by MrAnderson
^^^ what he said
Also, apart from the short stroke, bike engines rev hard because of a low reciprocating mass and the fact that all the mass is very close to the crank, eg the flywheel is small and the clutch is several small plates rather than fewer large plates. I can't remember the technical term for it ><... moment of inertia?? Can't remember but I'm sure someone will :(
Anyway, find and engine that doesn't have much weight to spin up, a short stroke (as mentioned already) and where all the mass is fairly central and you'll end up with a rev-happy engine. In my understanding the short stroke and having a stroke much shorter than the bore width makes it peaky (ie you need to rev the engine to make good power), and the rest makes it happy to do so.
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
    • Thank you so much for the help
