hey guys.. jus having abit of a problem ive drained my oil and removed oil filter as you do and when i went back to putting on the sump plug it wouldnt tighten into place. i assumed it was a washer so i tried few different ones but same problem.. looked at my sump plug but the thread is perfect.. so im assuming the thread which holds the sump plug in place is the one that is farked? as there was bits of thread stuck to the magnetic sump plug.. anyone got a quick fix?
lol thanks
https://www.sau.com.au/forums/topic/132605-oil-sump-plug/
lol thanks
To stuff the thread you first have to cross-thread it. If the thread is damaged you will have to run a tap thru it to clean it up. If its that far gone you might have to put a recoil in it...Kinda a bad situation to be in as the consequences if it leaks or comes out completely are clearly far from good.
Dont take any chances
Hope this helps,
Deren
https://www.sau.com.au/forums/topic/132605-oil-sump-plug/#findComment-2457543
justjap have a sump plug with a different thread all together with a magnet attached. after the rebuild this is what i used to pick up all the metal shavings. it doesnt leak and it fits in tighter than my standard plug. give it a go, theyre only around $15.
https://www.sau.com.au/forums/topic/132605-oil-sump-plug/#findComment-2459040
yeah dont strees too much. This one happend to mine. the thread was rooted so I had someone else (didn't trust myself) just drill it out and cut a thread for a larger plug. no problems since. :)
https://www.sau.com.au/forums/topic/132605-oil-sump-plug/#findComment-2459144
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
    • Yeah, I would have said the same. It makes me suggest that there are other things wrong, such that the ECU is totally unhappy with the broken sensor. The only other thought here is that maybe it is shorted, which might cause a different issue to the typical "disconnected" sensor.
